Old 07-24-2012, 06:03 AM   #301
plummers's Avatar
Originally Posted by Skiddins View Post
How did it go in the end with 30deg on the motor? What were the temps like?
Skiddins
hi skiddens, i went down a couple of teeth on the pinion and put the timing to 30 degrees. motor came off at 65 external and about 85 internal its still a bit smelly still but hopefully that will stop with time.
gonna try more timing friday hopefully if im feeling brave
thanks for your help. plummers
plummers is offline   Reply With Quote
Old 07-24-2012, 08:25 AM   #302
Skiddins's Avatar
It's the external temp that matters and 65degC will be fine.
It's a good idea to put a small square of black gaffer tape on the outer can. As it's less reflective it gives a more accurate temperature reading than just using the can itself.
I would try a blue rotor as well.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-03-2012, 01:33 AM   #303
Skiddins's Avatar
Has anyone used the Thunder Power bearing removal tool?
How does it work and will it only remove bearings from the can, or from the sensor end as well?
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-14-2012, 02:02 PM   #304
What size rotor is best suited for Boosted 17,5 stock 1:10 touring on small indoors track. Should i go with stock one or do i wanna change it to another for that last punch/speed.. Using a Hobbywing Xtremestock esc...
<Awesomatix A700 EvoII><Highest><Sanwa><Muchmore><Fantom>
<Awesomatix A800a><Hitec><Sanwa><Muchmore><Fantom>
<VBC LightningF><Hitec><Sanwa><Muchmore><Skyrc>
<=Team Autopartner=>
Gillblade is offline   Reply With Quote
Old 08-15-2012, 11:19 AM   #305
Wacker1's Avatar
Hi all,
I've just recently Bought one of these Thunder Power Z3R 13.5 Motors for my 1/12th Scale Car.
The 1/12th Scale 'GT12' Class that we do is on an Average sized Indoor Carpet Track, with a 1S Lipo & the Speedo is in Non Timing 'Blinky' Mode!
I just wondered if anyone could give me a good Starting point on Gearing/Rollout?
Ideal Timing used on the Motor?
Sticking with the Std Rotor or Upgrading?
Thanks.
Wacker1 is offline   Reply With Quote
Old 08-15-2012, 01:38 PM   #306
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by Wacker1 View Post
Hi all,
Thanks.
some were around 60mpr and 30 on the motor
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 08-15-2012, 03:19 PM   #307
Is the top speed and motor temps similar with the 13.5 motor regarding the (3) different rotors available?
Juan Aveytia is offline   Reply With Quote
Old 08-15-2012, 04:34 PM   #308
Skiddins's Avatar
I have generally found that using higher torque (higher gauss) rated rotors can reduce the temperatures slightly.
I found the blue to be slightly punchier than the red rotor.
I have yet to try the green rotor, that will be next.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-15-2012, 05:48 PM   #309
racespecs's Avatar
Originally Posted by BlackedOutREVO View Post
Will they puff like the batteries?
Kidding aside, they look nice! If Paul was in on the design im sure there dialed
Normally here good things about TP perhaps they save money on the lipo's then
________________________________________________
---------RC4ME - JQ - Savox - Alpha - Spektrum---------
racespecs is offline   Reply With Quote
Old 08-15-2012, 08:50 PM   #310
Has anyone tested the difference between the blue and green rotors in 13.5? Was the top speed the same? Everyone's experience will be very helpful. Thanks in advance.
Old 08-17-2012, 08:35 PM   #311
Old 08-17-2012, 09:26 PM   #312
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Top speed is never the same when you change something in the motor and nothing else.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 08-18-2012, 02:27 AM   #313
Skiddins's Avatar
I know that Plummers, tried the green rotor last night in blinky and said it made a huge difference.
His car certainly looked quick to me.
I also tried the green rotor for the first time in 13.5 boosted.
When geared up my car seemed sluggish but the lap times said different.
I nned to experiment more with timing and the RPM settings on my ESC.
I Qulai'd 3rd, blue car with yellow and orange striped front end.
+ YouTube Video
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-18-2012, 03:56 AM   #314
plummers's Avatar
yep can confirm what skiddins said, big improvement with the green rotor in, hall was ambient at 25 degrees, motor timing at 35 and geared to 4.5 in blinky. consistent through the whole run and motor came off at 70. usually struggle to keep motor temps down but the green rotor helped alot. plummers
Old 08-18-2012, 07:07 AM   #315
Thanks, I only have the green rotors and heading to the Tamiya Nationals next week. So, it sounds like your power and top speed were on pace with everyone else. That's good to know. Thanks for the reply.
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
