Old 06-24-2012, 12:01 AM   #271
Originally Posted by ThunderPowerRC View Post
The temps are within the range it should be. The only way to test the rotor is with a gauss meter. Same for the stator if you can check with a resistance meter. If one pole has gone bad you will see high resistance. Loosing cog can be caused by loss of rotor gauss or a stator starting to short.
so what is the normal meter value on rotor or sator ?
GP: Mugen MRX-6, Serpent Cobra GT 3.0
Engine: Tesla 7 port on-road, Tesla 5 port GT, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 06-24-2012, 04:46 AM   #272
jimkoimanis's Avatar
Hi guys
Got a thunder power 17.5 motor with a12.5 high torque rotor
I run 4wd off road
Is it better to gear down and turn the timing up or to gear or high and turn the timing down on the motor
I run a 69 spur with a 33 pinion final drive off 5.3
Thanks Jim
tamiya tao2 gt4,fav,bear hawk,team associated sc10, b4.1, sc18, tc5r,t4 j82. cougar sv pro dirt spec durango dex210 cat sx3 Schumacher k1 tekin gen2 d3.5 17.5 X-ray 808e xray xb9 13 spec os speed 21xz-b spec2
durango 410darc spec orion r10 pro orion vst
sponsored by habib's bodies
jimkoimanis is offline   Reply With Quote
Old 06-28-2012, 12:49 PM   #273
ChadRacing's Avatar
Can someone help me with my gearing and possible ESC settings on a Tekin RS PRO. I'm planning to put in a TP 7.5 into my Xray T2 '009.
Also I am using a TP 8.5 1cell in a WGT. What type of rollout and ESC settings( Tekin RS PRO) do I need to be around for this setup.
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 07-02-2012, 01:40 PM   #274
Default Sensor
Hi, wish to know. What cause the sensor ocassionally fail after 1-2 min run?
Is the sensor completely dead? or too much free play from the shaft to housing causing the sensor distance too far? thx!
Old 07-02-2012, 05:23 PM   #275
Skiddins's Avatar
Originally Posted by jimkoimanis View Post
Hi guys
I run 4wd off road
Thanks Jim
This is what I have been thinking about.
I believe if you are using the high torque rotor you should gear up and reduce the timing. (the higher gauss of that rotor will reduce it's top rpm).
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-03-2012, 12:47 AM   #276
Skiddins
I geared down and turned the timing up to full on the weekend and the car was a bullet finished a lap in front of everyone else and motor was only getting to 70 degress after 5min race
Old 07-03-2012, 12:58 AM   #277
Midwest_Mudder's Avatar
I gotta say, even though i had a motor literally smoke on me it was running super strong. Emailed the company got a super fast reply. Been lazy so far on my end but hope to be shipping the motor out to em. I LOVED that motor.
First in.... Last Out. Interior Rescue
I can barely keep track anymore....
Midwest_Mudder is offline   Reply With Quote
Old 07-03-2012, 03:30 AM   #278
Skiddins's Avatar
Did you also try going the other way?
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 07-03-2012, 04:15 AM   #279
Yep but it got hot really quick
All I can say is that the more I go down in pinion the faster it go's I'm run 69/30 and 45degress of timing in a Schumacher cat sx3 thunder power g6 5000 saddle packs and the 17.5 motor with ht rotor and the thing is a bullet heaps off bottom end and to much top end but I love it
Old 07-03-2012, 04:18 PM   #280
ChadRacing's Avatar
So no one can help me with this?
Team Durango DEX210
Old 07-05-2012, 09:00 AM   #281
plummers's Avatar
Default thunder power and a gm 90
hi, im thinking of running a thunder power motor. my question is, are the ok with gm 90 2010 speedos running in blinky. i usually run gm motors, what kinda gearing is a good starting figure. the track is indoor 30 metre straight at newbury(skiddens knows it)..thank you in advance. plummers
plummers is offline   Reply With Quote
Old 07-05-2012, 10:34 AM   #282
Skiddins's Avatar
I'd start the gearing on whatever the others run at Newbury. Somwhere on here was mentioned that the best amount of timing in blinky was around 35deg.
Gear a bit conservative and see what happens.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 07-05-2012, 10:36 AM   #283
Skiddins's Avatar
Trouble is you're running motors that not many people use.
What was your gearing on your previous motor etc, then go from there.
The Thunder Power do seem to be able to take a wide range of gearing without immediately melting.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 07-05-2012, 06:25 PM   #284
Default Z3R-S 21.5
I have the 21.5 for USGT Class ... Nice !!! ... paired upn with LRP ESN ... even though I am still using NiMh paks I can at least keep up ... not in last place anyway ...
Bolio 32 is offline   Reply With Quote
Old 07-06-2012, 12:13 PM   #285
Bishop's Avatar
Got to run my new 10.5T motor tonight, left at 20 timing, I ended up with a 4.8 FDR, or 41.888mm roll out.
Super cold night so I was wary of pushing it being so new, running around 65C, although then in the second final I pushed the timing to 25 and it came off at 60C, I suspect that means I'm getting close to the sweet spot?, at this point I'm unsure if to try more gear, or crank more timing?.
What is a little odd, to me anyway, if I did not match my best times with the Hobbywing motor, the ZR3 felt like it had more bottom to mid, but it's not translating to faster overall yet.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 09:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 01:29 AM
SEO by vBSEO 3.5.0
