Old 06-13-2012, 02:29 AM   #256
M24
M24's Avatar
Default TP 21.5 Blinky class
Any suggested set up for an Xray T3 2011 running in 21.5 blinky class? Plenty in this thread for the quicker classes, but not too many for us slower drivers that can't handle the quicker classes.
Current settings are an FDR of 3.35 (which is a roll out of 59.08). Timing is currently set at 37 degrees. Standard rotor. ESC is a Tekin RS and temps are approximately 150 F / 65 C at the end of a race run.
Car is quick through the infield but loses out slightly down the main straight which is about 30 metres long. Seems quicker than other TP powered cars running a couple of teeth taller gearing but less timing.
Any thoughts will be much appreciated.
Greg
Bro-Kin Racing - Team BRG
Castle Hill Raceway
Xray T3-2011
M24 is offline   Reply With Quote
Old 06-13-2012, 11:29 AM   #257
Bishop's Avatar
Does anyone know a good and safe starting FDR or Rollout for 10.5T blinky class on road?, just ordered a TP motor to replace my fading HW motor, I have been running the HW at absurd levels, but mainly cause it's got very low fixed timing.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 06-13-2012, 11:40 AM   #258
NolanP's Avatar
It depends on how big of a track you are running
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 06-13-2012, 12:04 PM   #259
Bishop's Avatar
Two configurations, on a large outdoor track, one I guess would be large by electric standards, with a couple of fairly long straights, the other run more regularly is quite short and constantly turning, but still with one medium length straight.
I'd feel safer going in with a ball park safe zone for the TP motor, I know I cooked a SP motor when we went from turbo to zero, at not such a extreme FDR, yet on the HW motor now I'm down/up to a 48mm or more rollout (though it is winter right now and around 10-15C on track at night).
QRCCRA
www.qrccra.org.au
Old 06-13-2012, 12:06 PM   #260
NolanP's Avatar
My guess would be 4.5 to 5.0 to start then.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 06-13-2012, 08:18 PM   #261
I have heard the the Reedy and Thunerpower motors are the same motor with cosmetic differences? Can anyone confirm this? Thanks
Jeremy Otis is offline   Reply With Quote
Old 06-13-2012, 08:35 PM   #262
stiltskin's Avatar
Trader Rating: 99 (100%+)
Here's a breakdown of two 17.5 motors. Rotors are slightly different. Other internals appear to be identical, but I didn't take any measurements to confirm. Either way, both are very good motors.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 06-14-2012, 02:20 AM   #263
Skiddins's Avatar
They are similar, but not the same, for a start the main bearings are different which means the size and position of the rotor is not the same.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-18-2012, 06:32 AM   #264
Greg
Any suggestions??
bitisbitis is offline   Reply With Quote
Old 06-23-2012, 03:23 PM   #265
Default Rotor or sator!??!?
I just got a brand new 5.0T motor today, and test it.
The speed is crazy, i like it. But, when after 4 minutes run, the motor seems lost the magnetic force. I tried another 3 minutes, the speed got no different but no brake force generated.
I don't think it's overgear, the motor tempertature was 55C (at most 60C) reading from heat gun.
Here's my set up.
-motor timing, maintain 20, no change
ESC timing:
- boost timing: 4
- boost start: 14000 rpm
- boost end: 34000 rpm
- turbo start: 35000 rpm
- turbo timing: 25
- turbo operating speed: 300m sec
- turbo return speed: 300m sec
Battery:
7.4V 6800mAh, 70C
So which part should be replaced? Rotor or sator? Thx!
GP: Mugen MRX-6, Serpent Cobra GT 3.0
Engine: Tesla 7 port on-road, Tesla 5 port GT, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 06-23-2012, 04:21 PM   #266
Skiddins's Avatar
Here's my set up.
ESC timing:
- boost timing: 4
- turbo timing: 25
Battery:
7.4V 6800mAh, 70C
How were the lap times?
It could be that the ESC is getting hot, not the motor.
Skiddins
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 06-23-2012, 08:28 PM   #267
Trader Rating: 18 (100%+)
Skiddins
i was gonna suggest esc too. but i dont think it would have as much effect as a bad lipo. try a different lipo. diff brand/rating
johnny lee is offline   Reply With Quote
Old 06-23-2012, 09:46 PM   #268
It's phyiscally losing notchy feeling when i turn the gear. Like I said the speed didn't lose at all, but the brake.
I's new new lipo pack, new ESC.
Old 06-23-2012, 10:35 PM   #269
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Maybe you bumped a setting on your radio reducing brake strength?
Old 06-23-2012, 11:29 PM   #270
ThunderPowerRC's Avatar
Here's my set up.
ESC timing:
- boost timing: 4
- turbo timing: 25
Battery:
7.4V 6800mAh, 70C
The temps are within the range it should be. The only way to test the rotor is with a gauss meter. Same for the stator if you can check with a resistance meter. If one pole has gone bad you will see high resistance. Loosing cog can be caused by loss of rotor gauss or a stator starting to short.
ThunderPowerRC is offline   Reply With Quote
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 09:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 01:29 AM
SEO by vBSEO 3.5.0
