Old 05-22-2012, 08:14 AM   #226
MikeXray's Avatar
Trader Rating: 72 (100%+)
Originally Posted by hanulec View Post
Use your thumb to remove the stator... just wedge it into where the rotor goes. If you melted the stator you might need to use a soldering to remove any solder peaking through the can.
Listen to this guy, he knows the WAY!!
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-22-2012, 11:37 AM   #227
Trader Rating: 212 (100%+)
Originally Posted by Tamiyarchie View Post
Ok weird. Is there a trick to it? Mine seems to not easily pull out. I though there must be more screws holding it in or something
You do have the 3 screws out of the can on the pinion end, right? Just asking.
Andy Koback is offline   Reply With Quote
Old 05-22-2012, 12:03 PM   #228
Hello,
Just bought 4.5 thunder power. I'm wondering which timing and final ratio do I have to use for a medium sized outdoor track.
Also I use a Orion r10 pro, does anyone have a good starting setup with this speedo?
Thanks in advance.
Hugo is offline   Reply With Quote
Old 05-25-2012, 02:58 AM   #229
XSLR8's Avatar
Originally Posted by Craig W View Post
25 on motor
frd around 4.5
with hw or sp boosted
9
44
18
16
400
3k
some thing like that
FDR 4.5 on a 21.5 boosted? Really ?
VBC Racing Australia.....FUTABA AUSTRALIA.....Volante tires.....WTF Fans.....R.A.B Hobbies....President www.serccc.com.au
XSLR8 is offline   Reply With Quote
Old 05-25-2012, 04:16 PM   #230
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Hugo View Post
Hello,
Thanks in advance.
I'd start with about 10* motor timing and try an 8.8 FDR to start. Definitely temp after a couple minutes though as outdoor racing can vary widely in temperature. I don't know specifically for an Orion, but I would start in blinky mode with whatever the linear throttle profile is and no boost. Add drag brakes to taste.
AWD
Old 05-28-2012, 09:00 AM   #231
Originally Posted by stiltskin View Post
Has anyone found the melting point yet on these motors? What temps have you seen and still managed to not roast the motor?
Mine came off at 80'C yesterday
mcdoogle is offline   Reply With Quote
Old 05-28-2012, 01:39 PM   #232
Default No Brakes with HobbyWing V3 esc
Hi,
just got my HobbyWing V3 esc and trying this new TP 13.5 motor but i seem to have very little brakes. Anyone else had this problem ? i'm running fdr approx 5.9 on a tarmac outdoor track which has a 50m straight.
Old 05-28-2012, 01:59 PM   #233
KJR
anyone tried replacing the screws on the timing endbell ? they seem to be made of cheese and would like to replace them with hex head screws but not sure if they are metric or imperial ?
KJR is offline   Reply With Quote
Old 05-28-2012, 03:17 PM   #234
Skiddins's Avatar
I believe they are M2.5
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-29-2012, 02:48 PM   #235
KJR
Yep,
got some M2.5 * 10mm and they fit perfectly. Looks a lot better and a lot easier to adjust.
Old 05-29-2012, 03:06 PM   #236
stiltskin's Avatar
Trader Rating: 99 (100%+)
Could someone explain the difference between the 4.0 and 4.5 motors. Is it just a different feel, power band, torque, whatevr. Thanks.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 05-29-2012, 07:35 PM   #237
ThunderPowerRC's Avatar
what we call 0 winds are used where you dont need to go a whole wind for power as they are 1/2 wind less.
ThunderPowerRC is offline   Reply With Quote
Old 05-30-2012, 12:07 AM   #238
racer x 1's Avatar
Trader Rating: 27 (100%+)
whats the best rotor to use for blinky 17.5 sedan on med bite carpet? also how does it like to be geared? Its a fairly small track.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 05-30-2012, 01:13 AM   #239
Green or blue rotor, is the best for blinky.
This winter i ran a smalle carpet track Fdr was around 4.0
Cp Grafix is offline   Reply With Quote
Old 05-30-2012, 07:41 PM   #240
stiltskin's Avatar
Agreed. I ran the blue rotor this winter with good success. Haven't tried the green rotor, but it should provide a little more torque over the blue. Time the motor at around 38* with a 3.8 to 4.0 fdr. I always ran a fan on the motor as well. Very happy with the performance of the Thunderpower motors.
Tony Rumple
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 09:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 11:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 01:29 AM
SEO by vBSEO 3.5.0
