Old 05-11-2012, 04:57 AM   #211
XSLR8's Avatar
Originally Posted by XSLR8 View Post
Hi guys,just wondering if anybody has any good starting settings for medium size outdoor track running 21.5 boosted tc. Hobbywing esc,xray t3 2012. What would be a good ballpark FDR as I am new to this motor,track has two medium size straights and two technical infields.
Any help would be greatly appreciated.
Cheers.
Anyone ???
VBC Racing Australia.....FUTABA AUSTRALIA.....Volante tires.....WTF Fans.....R.A.B Hobbies....President www.serccc.com.au
XSLR8 is offline   Reply With Quote
Old 05-11-2012, 10:32 AM   #212
idbdoug's Avatar
Trader Rating: 33 (100%+)
Question about rotor upgrades for a 17.5???
What rotor would I want to use in blinky TC with a 17.5???
What rotor would I want to race in blinky 2wd buggy??
Thanks for any further information
idbdoug
idbdoug is offline   Reply With Quote
Old 05-14-2012, 03:15 PM   #213
racer x 1's Avatar
Trader Rating: 27 (100%+)
idbdoug
+1 need gearing advice for 17.5 blinky blink and fdr
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 05-14-2012, 04:09 PM   #214
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
for tc around 3.5 to 4 with 35 on motor
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 05-14-2012, 04:09 PM   #215
Craig W's Avatar
idbdoug
i would say green
Old 05-14-2012, 04:11 PM   #216
Craig W's Avatar
Anyone ???
25 on motor
frd around 4.5
with hw or sp boosted
9
44
18
16
400
3k
some thing like that
Old 05-21-2012, 01:38 PM   #217
Default LRP Stock Spec V2 - TP 13.5
Hi
Have anyone a good setting for this esc for 13.5 boosted class?
Any advice on esc settings, FDR etc will be highly appreciated.
I am running a Schumacher Mi4CXL
Ole Jacob
Schumacher Mi4CXL
Thunder Power 13,5
LRP SXX V2
Viking73 is offline   Reply With Quote
Old 05-21-2012, 03:48 PM   #218
Skiddins's Avatar
Anyone know what sort of FDR's were being used by the other Thunder Power runners at Cotswold for the BRCA meeting.
I've been running around 25deg motor timing with the blue rotor and was geared at 7.08 (top speed for me was measured at 51mph)
In the last final I geared at 6.65 with 20deg motor timing, this did give higher top speed but the mid range grunt was missing (few tenths slower).
This was my first final of 3 (blue car with yellow and orange stripes;
+ YouTube Video
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-21-2012, 04:11 PM   #219
Hi guys. Sorry for the noob questions
I got one of these motors and I want to change to the ceramic bearings. I got the bearing replacement tool and I got the bearing out of the end bell but how do I get the one out of the can? Do I need to take the stator out? If so, how do I do that. Sorry again for noob questions.
Tamiyarchie is offline   Reply With Quote
Old 05-21-2012, 05:18 PM   #220
Trader Rating: 216 (100%+)
Yep, stator comes out!
Andy Koback is offline   Reply With Quote
Old 05-21-2012, 06:51 PM   #221
Cool. How do I get the stator out?
Old 05-21-2012, 07:02 PM   #222
elee32's Avatar
Trader Rating: 18 (100%+)
it'll just pull out from the red can once you've removed the endbell
elee32 is offline   Reply With Quote
Old 05-21-2012, 08:56 PM   #223
Ok weird. Is there a trick to it? Mine seems to not easily pull out. I though there must be more screws holding it in or something
Old 05-22-2012, 06:43 AM   #224
MikeXray's Avatar
Trader Rating: 73 (100%+)
it is a tight fit, it helps to twist the red cap, usually once it frees up a little it comes right out. If its really stuck use like a 2.5mm driver and push on the stator from the front side, carefully.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-22-2012, 07:11 AM   #225
hanulec's Avatar
Use your thumb to remove the stator... just wedge it into where the rotor goes. If you melted the stator you might need to use a soldering to remove any solder peaking through the can.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
