Old 04-24-2012, 02:06 AM   #196
Skiddins's Avatar
Originally Posted by ThunderPowerRC View Post
What we have found is the taller the gear the less timing you need to use. In non boost 35deg seams to be the magic number. I wouldn't go more that 38deg.
Have you done any testing with boosted stock TC's yet, i.e. 10.5 & 13.5?
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-24-2012, 02:10 AM   #197
Skiddins's Avatar
Saw a boosted 10.5 TC running Thunder Power on Sunday for the first time.
It was at least as quick as all the other cars out there including the 5 times UK champion etc.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-25-2012, 07:37 AM   #198
Quick question:
Here in Denmark, the rules for outdoor have just been released. It is going to be 13.5T "blinky". What would be a good starting point for a Thunder Power motor, on a medium-big outdoor track?
I see a lot mentioning the green and blue rotors, but we are not allowed to switch the rotor, so it has to be the stock rotor.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 04-25-2012, 08:21 AM   #199
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by Nilks View Post
Quick question:
god start point would be 4.5 fdr
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 04-25-2012, 07:52 PM   #200
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
The stock red rotor is great. I wouldn't worry about not being able to swap rotors.
Old 04-25-2012, 10:10 PM   #201
Default 13.5 STARTING POINT
Anyone got a good starting point for use with a Tekin RS running 13.5 Boosted with a FDR of 6.15ish, I found the setting I was using with my SP V3 and Duo 3 is a bit boggy down low, I had the boost comming on quite early with them so will try increasing the start rpm, the track we run on has a tight we infeild but a massive main straight, any info would be grand.
B.C.Ninja is offline   Reply With Quote
Old 04-26-2012, 02:42 AM   #202
Skiddins's Avatar
You could try running around 25deg motor timing.
Don't max anything out on the ESC at first keep the temps in the 50's degC range.
Depending on the length of the straight you might find that lower gearing and a bit more timing might help you.
Do you have any photo's of the track?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-26-2012, 04:27 AM   #203
Skiddins
I ran mine in Cotswolds at the weekend and it was really good, I back to backed it with SP MMM motor and found it a lot better, I had motor timing set at around 28 with 40 boost and 24 turbo geared at 7.8..
kdempsey is offline   Reply With Quote
Old 04-26-2012, 04:46 AM   #204
Great thanks. What about endbell timing?
Niklas Hansen
Old 04-26-2012, 04:58 AM   #205
Craig W's Avatar
try max 35
Old 04-26-2012, 05:04 AM   #206
try max 35
Thanks, I will.
Niklas Hansen
Old 04-26-2012, 05:28 AM   #207
Skiddins's Avatar
I know James Hart was running one (it was his I was reffering to) and was geared at 7.0.
What ESC were you using?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-26-2012, 05:48 AM   #208
I ran SP 2.0, I was happy with motor/speedo so I didn't change to much after that. Great track
Old 05-07-2012, 08:56 PM   #209
Is there a limit to the amount of timing that can be applied to the Z3R motor? I understand the motor has end bell up to 50 degrees but how much more timing can you apply via the ESC theoretically (I'm not talking real world heat, failure etc )
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 05-07-2012, 10:36 PM   #210
StevenOlsen's Avatar
If you look at it just theoretically, I would say max so around 50* on motor and depending on esc from 64* on a SP to 75* on a tekin so a total og 114 to 125*
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
