Old 03-02-2012, 04:24 AM   #136
Skiddins's Avatar
Originally Posted by donwhit View Post
Hi Skiddins,
Tried one pinion lower (16) at Stafford tonight. Ian said it was better on the short straights. Also tried a 15, gutless. Also tried an 18, seemed overgeared on same speedo settings.
Also tried the thin topdeck in the last round, Ian reckoned it gives more 'in corner' steering on a 2012.
Everyone I know who uses a Tekin tends to run 50 timing (max'd out) and around 5-10 turbo when running 13.5's
We used to run 40 on the timing when using 10.5's
Might be worth trying to run more on the ESC and less on the motor and see if the torque increases.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-02-2012, 07:55 AM   #137
Originally Posted by defcone View Post
for the snowbirds /iic setups, how much timing on the can was used?
Sorry... offtopic. Is that Gate's X in your Av?
You follow TA in the US?
JamesL_71 is offline   Reply With Quote
Old 03-02-2012, 08:25 AM   #138
defcone's Avatar
Trader Rating: 15 (100%+)
Technically no, it's a 9. Yes, but only every so often, when nothing else is on.
http://ns223506.ovh.net/rozne/6e437c...er-1721298.jpg
Full size^
Thought I'd make my question clearer, for this setup how much motor timing was used?
17.5 Boosted TC
50 boost
15 turbo
5000 -14000 rpm
.1 delay
10 min throttle
10 min brake
2 ramp
geared around 5.5
Red rotor
defcone is offline   Reply With Quote
Old 03-03-2012, 08:00 AM   #139
Skiddins's Avatar
Hi Skiddins,
Tried gearing from, 7.60 to 7.98 tonight with motor timing at 30deg
The following is my final (I was car 2, dark blue with pink looking front end using 7.98 FDR)
It was coming off around 61degC with only a small passive heatsink, no fan.
+ YouTube Video
For once I was as quick as the turbo esc cars down the straight. But my drivng wasn't good enough for the A Final (Newbury only run 8 car finals)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 03-03-2012, 11:25 AM   #140
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
+ YouTube Video
for blinky racing you are going need blue rotor
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 03-03-2012, 11:42 AM   #141
Fred Hubbard's Avatar
or green.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 03-03-2012, 12:11 PM   #142
Skiddins's Avatar
Originally Posted by Fred Hubbard View Post
or green.
We don't do blinky racing so not a problem
Changing the rotor would also stop it being legal at our nationals
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 03-03-2012, 12:44 PM   #143
Craig W's Avatar
red blue and green were sent to Paul at the same time as motor so should be legal but i am waiting for email to confirm this and i have spoke to Andy at rc explorer uk as well and he is a waiting same e mail
Old 03-03-2012, 12:49 PM   #144
Skiddins's Avatar
Ok, so whats the difference between the rotors?
I believe the standard item is 1300gauss (I did measure it but forgot to write it down
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 03-03-2012, 01:01 PM   #145
Craig W's Avatar
blue is the torque rotor factory advise to run in blinky classes
Old 03-03-2012, 02:06 PM   #146
Blue is a 12.3mm Torque and Green is a 12.5mm High Torque. Running the green yields more bottom end than the blue, runs cooler and you can gear up about 1 tooth from the blue and/or run a bit more timing.
Old 03-03-2012, 05:28 PM   #147
stiltskin's Avatar
Trader Rating: 102 (100%+)
Has anyone found the melting point yet on these motors? What temps have you seen and still managed to not roast the motor?
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-03-2012, 09:14 PM   #148
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
With about all motors if you get it to 190-200 it might smoke. I have had mine hotter than that without smoking but I wouldnt try it.
160-170 is what I would consider a safe operating temp. Anything over that might be ok but with all motors anything over that is pushing it.
To whoever asked I would run around 30-35 timing in boosted 17.5 Touring.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 03-03-2012, 09:20 PM   #149
texastc's Avatar
Originally Posted by ThunderPowerRC View Post
F1 settings from Viktor Wilck car at IIC.
21.5 no boost
Blue rotor
38* timing
32-94 Gear
Tire - Ride soft
I am running the stock rotor. What changes in timing should I consider? I have never really messed with timing much before. But this is the Nats, time to man up.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and another Exotek F1Ultra on the way. And whatever is next
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom "you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 03-04-2012, 01:46 PM   #150
Skiddins's Avatar
Did some more running today at a larger indoor track.
Same venue but not this layout. You get the idea;
+ YouTube Video
From my notes;
FDR 7.98 Motor timing 27deg, felt good, temps 50degC
FDR 7.98 Motor timing 30deg, felt good, temps 61degC
FDR 7.98 Motor timing 32deg, felt good, temps 71degC
The more timing, the faster the car felt down the straight but brakes became a bit weaker at high speed. Car felt fast out of corners.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Ask Paul Lemieux, RC America/MOTIV/Gravity RC Paul L Electric On-Road 2761 01-06-2017 08:46 PM
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
** CHALLENGE CUP 2011 ** TJ Australian Events 1140 12-01-2011 12:29 AM
