Old 01-03-2011, 01:25 PM   #1
Trader Rating: 25 (100%+)
Default Hpi sprint 2 350z body
If I have a hpi 190mm 350z body what offset rims would I need for the front and the back. I have some work xsa rims 3mm and 6mm offsets. Just wanted to find out some information. Its going on a sprint 2. Will the 3mm work for the front and the 6mm work for the rear. Will they stick out to much or will they be flushed with the body.
ETOWN is offline   Reply With Quote
Old 01-04-2011, 07:27 PM   #2
HPI suggest for 190mm Bodies front - 0mm offset rear - 3mm offset
for their 200mm front - 3mm rear - 6mm
But that is for HPI bodies..I dont know what other bodies will run you may just have to play around and see what you like the best.
Dill004 is offline   Reply With Quote
Old 01-09-2011, 05:08 PM   #3
sliding_josh's Avatar
Trader Rating: 21 (92%+)
Yeah om most yokomo bodies you will need 3-6mm and you will be fine, any wider offset lkke 9-10mm will be to much and stick out way to far! But on the yokomo 350z the wheel wells are wide and you can fit a 9mm but have to run alot of camber for the top of the rim to tuck in flush!
On my HPI 350z I have some custom 9mm gram lights 57pros, and they sit tucked in with like -3/-4 of camber on a Yokomo chassis!
and on my HPI MKll Chaser 200mm body even a 9mm wont sit flush with the body so im running Traxxas 12mm grey spacers for them to sit flush!
FaceBook>>> RC Drift Machines
sliding_josh is offline   Reply With Quote
HPI Sprint 2 rando_6289 R/C Items: For Sale/Trade 9 09-05-2010 12:48 PM
HPI Sprint 2 Drift DaveNJ80 R/C Items: For Sale/Trade 9 10-21-2008 05:58 PM
SEO by vBSEO 3.5.0
