Old 07-31-2004, 10:45 PM   #1
onebeatuptc3's Avatar
Send a message via AIM to onebeatuptc3
Default Should I consider a new batt pack?
Ok, tonight i set my battery down and a few minutes later i notice a glow coming from the pack, but fortunately, when this metal object crossed 2 of the cells, it only really heated up that object and melted it like solder, but there is some damage to one cell (it chared part of the outside of the pack.
The battery is a club grade fusion pack. After I let the pack cool, i charged it and the battery's mah was 2983 from the 3300 cells, with about 8.82 v's. (at 5 amps) The AIR was also a little high, about 29.3 ohms, with the cells getting up to a temp of 117 to 121 degrees. Does this seem that the batteries have been damaged significantly, or can only one damaged cell be replaced in the pack to make it normal again? Thank you.
onebeatuptc3 is offline   Reply With Quote
Old 08-01-2004, 12:29 AM   #2
Neil Rabara's Avatar
It sounds like the pack was damaged. The peak is too low. Your capacity decrease also. Send it back to Fusion and see if they can rematch it.
Neil Rabara is offline   Reply With Quote
Old 08-01-2004, 03:30 PM   #3
Wency_TA03R-PRO's Avatar
You might have a dead/damge cell on that packs.. if you're in doubt in testing w/c one is def neil is right its better to return it back to fusion service to verify the damage cells.
Wency_TA03R-PRO is offline   Reply With Quote
wtb 3PK batt pack 1shnot R/C Items: Wanted to Buy 3 10-25-2007 11:12 PM
Fukuyama batt pack Roberto Falcon R/C Items: For Sale/Trade 4 06-08-2005 09:32 AM
what's the highest AAA batt pack? V-1-R Singapore R/C Racers 3 02-24-2004 09:46 PM
Batt Pack For Kyosho Evolva kenchoco Nitro On-Road 2 02-03-2004 07:57 PM
batt pack for kyosho evolva kenchoco Oval, Larger Scales and More 0 01-29-2004 07:32 PM
SEO by vBSEO 3.5.0
