Old 12-28-2010, 08:09 PM   #16
Mark506's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Crashby View Post
And here is a little tip I learned from the owner of TOP racing.
Take a cardboard box that your chassis and parts will fit in. Spray the inside of the box with CA kicker. You can use the pump type of spray or the aerosol type of kicker. You don't have to coat the complete inside of the box, just spray some on all sides and the bottom of the inside of the box. After wet sanding and getting your edges just the way you like them, coat the sanded edges with CA and then place the chassis or parts in the box with the kicker sprayed on the inside, close the box and wait maybe 30 to 45 seconds and remove your part. The edges will not only be dry but they will look like glass!! Speeds up the CA drying process will providing a great finish to the edges. Very neat trick. Thanks Vincent!!
What's CA kicker?
Mark Ament
l MOMO USA l OZ Racing l Willwood Brakes | Dunlop Tires |
The Raceway at Beaver: Forever In Blue Jeans
Mark506 is offline   Reply With Quote
Old 12-28-2010, 08:17 PM   #17
hairy's Avatar
It is a chemical that "cures" the glue in a few seconds rather than waiting for it to dry on it's own.it actually makes the bond much stronger.
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 12-28-2010, 08:29 PM   #18
All racer should file the edge especially if you run on carpet track. As just a small splinter from your chassis may damage the carpet and I don't think the track owner will be too happy when that happen.....
gpm-parts.com is offline   Reply With Quote
SEO by vBSEO 3.5.0
