Old 12-27-2010, 09:12 PM   #1
mytto1's Avatar
Questions?? Gearing suggestions please
I have a 12 turn double in my tao5 v2 and i have no idea how and what to gear a brushed motor. I only have a 70T spur and i have alot of pinions.
what should i gear it so its safe to run w/o frying the motor. im not too familiar with gear ratios and stuff.
mytto1 is offline   Reply With Quote
Old 12-28-2010, 08:57 AM   #2
jjfo80's Avatar
mate the spur your running will need a fairly small pinion if it will fit and the motor mount lets the gears mesh. A 12 turn brushed motor you will need around a final drive of say around 7.0 and work down from there.... with a internal ratio of 2.25 and a 70 spur and a 32 pinion will give u a fdr of 4.2 I think. so that will give you some idea.
But lots of things will come into consideration as tire size and track size and wether its fast or technical and so on.
Make sure your timing on the endbell is set mild so no where near 30* as with a brushed motor you need to find the sweet spot other wise your will wear the comm and the brushes out way to quick and make the motor useless.
Good luck and I hope anyone else see's anything I missed will chime in and let u know.
Owner of Precise Fuels and RC and Podified Fuels
jjfo80 is offline   Reply With Quote
M-04M Gearing and diff questions please gixer Electric On-Road 18 11-06-2009 04:40 PM
TA04 Pro gearing suggestions PIIHB! Electric On-Road 8 10-11-2002 09:03 PM
SEO by vBSEO 3.5.0
