Old 02-04-2011, 02:08 PM   #121
Originally Posted by rosko View Post
+1 on associated making their own gear diff
You and me, and others can vote, but AE will listen to this?
Put Yokomo, some work with dremel and done
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 02-04-2011, 03:12 PM   #122
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
Use the Yokomo gear diff.
http://www.driftspeed.com/index.php?...oducts_id=2921
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 02-04-2011, 03:54 PM   #123
rcscoot2539's Avatar
Originally Posted by Troy Mckune View Post
Kevin,
Any word on an Associated gear diff?
Are you running the stock front CVA Axles? I am finding I get some binding and vibration in the CVAs depending what my dual rate is set at. What do you do to fix or deal with this?
Thanks,
Troy
+1 un having the same thing happen
TC6 - B4.1 - LOSI SCTE - LRP - SPEKTRUM - SWEEP - AB CHARLES HOBBY SHOP - THE RACEWAY AT BEAVER
rcscoot2539 is offline   Reply With Quote
Old 02-04-2011, 04:05 PM   #124
Default Ballast Weights
Hey Keven, could you please post a picture of the TC6 ballast weights? I can't seem to find one anywhere.
Thanks,Anthony.
Handbrake is offline   Reply With Quote
Old 02-05-2011, 01:02 PM   #125
imjonah's Avatar
Default Carpet Rubber Setup vs Aspahlt
Assume after some effort I was able to come up with a good setup for carpet(17.5 rubber TC), how close would this setup be for prepared parking lot asphalt track?
Are there any adjustments which are standard or typical?
imjonah is offline   Reply With Quote
Old 02-06-2011, 11:42 AM   #126
Kevin, did you run a new setup at the snowbirds? If so can you post it. Thanks
franc furter is offline   Reply With Quote
Old 02-07-2011, 11:30 AM   #127
F-1
Hello Kevin!
What kind of pinion gear are you usually running with LRP 5.0 motor?
And what any special mods should I do with TC6 shocks? On some pictures I saw on TC6 shocks with old shocks bodies, what is that?
Thanks!
Associated B4.1 - SXX TC V2 - X-12 - Reedy - Proline
Associated B44.1 - SXX TC V2 - X-12 - Reedy - Proline (soon)
Associated TC6 - SXX TC V2 - X-12 - Reedy - Proline
- M11X -
Upgrade Rc 2010 Race Brigade Team
F-1 is offline   Reply With Quote
Old 02-07-2011, 12:30 PM   #128
Originally Posted by M.Abramowicz View Post
Hi Keven!
You still use HB cyclone double joint axles at front? Like in tc5?
Do you do some mod to steering block?
I put bd5 and I need to move inside bearing (it is easy to do), but got
info that spec-r not live long time in fast class.
Regards!
m
Hi there,
I have been running xray dual joint simply because hotbodies have been very hard to find ! I have not done any mod to steering block ! Right now I plan on going back to stock driveshaft in the front if using a front gear diff.
As for the spec R I have not had any issues with it in modified !
Originally Posted by Kody View Post
Thanks for the reply Keven!
Shoot I thought you guys were running the stock rotor with the 4.0. How will the stock rotor out of the 4.0 work? Anyway I will order the works 12.0. Just sucks as its not going to be in the motor for a practice day this weekend.
Hi Kody,
the stock rotor will work fine but will have a little more dragbrake than the 12.0 rotor. The 12.0 works seem to have more top end speed as well and a smoother feel.
Kevin,
Thanks,
Troy
Hi Troy,
I havew been running dual joint axle in the front simply because I have been running a spool but I am convinced that with a gear diff in the front the stock cvds wont be a problem ! As for an associated gear diff it is not out of the question for sure
Thanks,Anthony.
Unfortunately I don,t have the ballast weight yet ! they haven,t made it to associated. I will do when I get some.
I honestly dont change much from asphalt to carpet ! the main thing is usually we want a little more steering on aspahlt than we do on carpet ! Let say a very good asphalt setup might steer a little too much on carpet so I would start with the same setup and tune from there.
Hope this helps
I pretty much ran the same setup from Cleveland ( US indoor champs ) But I have been running Silver all around for spring lately thats about all I changed.
I will be doing some more testing in the next few weeks as I have a lot of races coming with the ETS in autria next week end, The 4th leg of the grand slam in 2 weeks and the Super stock National in 3 weeks. I will let people know of my finding on here .
Originally Posted by F-1 View Post
Hello Kevin!
Thanks!
I usualy run a 8.7 ratio with a 5.0 ! As for the TC6 Shocks, I did not do anything special with mine I built them the way it says and I have not had any issues yet. I heard some people sand the plastic piece where the oring goes so it doesnt squeeze it which is not a bad thing to do otherwise I wouldnt do anything special !
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 02-07-2011, 01:04 PM   #129
Hey Keven, I just put together the kit (tc6) and on the car stand I get a vibration went the tires are turned on power.
Any guess to what it could be. Thanks
and what cvds will work with the spool
Old 02-07-2011, 05:58 PM   #130
syndr0me's Avatar
Trader Rating: 32 (100%+)
Very cool you're going to ETS, good luck over there!
Would you mind verifying/completing some tech info for Snowbirds? Thanks!
Mod Sedan
Chassis: TC6
Motor: LRP (turns?)
ESC: LRP (model?)
Battery: Reedy
Body: Speed6
Radio: KO Propo
Charger: LRP
Traction: ???
Expert Sedan
Chassis: TC6
Motor: LRP X12
ESC: LRP SXX-SSv2
Battery: Reedy
Body: Speed6
Radio: KO Propo
Charger: LRP
Traction: ???
Mod 1/12
Chassis: AE
Motor: LRP (turns?)
ESC: LRP (model?)
Battery: Reedy
Body: ???
Tires: ???
Radio: KO Propo
Charger: LRP
Traction: ???
syndr0me is offline   Reply With Quote
Old 02-07-2011, 06:38 PM   #131
Blue Screw's Avatar
Send a message via AIM to Blue Screw
kevin.. couple questions for u.. 1 the upgrade lrp diode they sell for 1 cell or 2 cell for the speedo what does that do to help u compared to the stock one
i noticed on paul l 1/12 i think at the birds he had a rec pack hooked up to a sxx..????
an what would be the diff say 35-40wt oil with a 2 hole piston compared to say 60 wt with a 3 hole pistion that i notice the top car uses
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 02-09-2011, 08:29 PM   #132
Kevin, what did you have to change to run the xray ecs? (bearings,hex,caster blocks) Also what length 50 or 52mm. thanks
Old 02-10-2011, 05:35 AM   #133
walkonking's Avatar
Hi Kevin, Im running 17.5 boosted in TC6. What 64p spur gear should I start out with? Dont want to use 48p as i have a lot of 64p pinion gears.
Thanx.
pop a clutch, roll a dutch!
walkonking is offline   Reply With Quote
Old 02-10-2011, 06:38 AM   #134
Usually it will do it on the bench but wont be bad at all on the track, the one thing you can do is limit the steering throw by placing a small shim on the steering blockwhere it hits the castor block to limit it
[QUOTE=syndr0me;8617213]Very cool you're going to ETS, good luck over there!
Mod Sedan
Chassis: TC6
Motor: LRP ( 5.0 Octawind )
ESC: LRP Version 2
Battery: Reedy
Body: Speed6
Radio: KO Propo Eurus
Charger: LRP
Traction: SXT 3.0
Expert Sedan
Chassis: TC6
Motor: LRP X12
ESC: LRP SXX-SSv2
Battery: Reedy
Body: Speed6
Radio: KO Propo
Charger: LRP
Traction: SXT 3.0
Mod 1/12
Chassis: AE
Motor: LRP ( 4.0 )
ESC: LRP (Stock Spec)
Battery: Reedy
Body: Protoform AMR 12 Light
Tires: Parma
Radio: KO Propo
Charger: LRP
Traction: SXT 3.0
I put the answers in there.
Hi ,
There isnt much of a difference between the capacitor, it is just an improved version which is actually 3 capacitor into 1 ! but the difference is not something you can notice right away.
As for Pauls 12 scale I am not sure what he ran for esc but maybe he like the feeling better with a receiver pack as the servo is a little faster ? I am not sure sorry .
You can achieve the same with a 2 hole piston as you would with a 3 hole it just depends on what size the holes are ! I personaly have been running 3holes and done all my testing with 3 holes.
In order to run those you need to get 5x10x3 bearings and xray hex and dremel some material off the castor block. As I mentionned before, next time I get to go test I will go back to stock Driveshaft with a front gear diff.
Thanx.
Hi,
It is pretty hard to say considering all the esc being different and with so much adjustability now and motors being different it is hard to get a good idea for gearing but I would start somewhere around 6.3 to start with and see with motor temp !
Keven Hebert
Old 02-10-2011, 08:19 AM   #135
syndr0me's Avatar
Thanks Keven, got all your info updated.
