Old 01-24-2011, 09:32 PM   #106
Originally Posted by Maybell View Post
Hey sexy,
What rotor do you run in the 4.0 in your 12th scale?
Very good ? dude! Got my 4.0 last week... Cant wait for some mod 12th at the Hanger!
Ceramic bearings a must Kev?
Kody is offline   Reply With Quote
Old 01-25-2011, 07:58 PM   #107
i1justin's Avatar
Trader Rating: 20 (100%+)
you get lost kody? what are you doing on the Associated/LRP/Reedy thread
Great run last weekend
Justin Wilde
AE - Reedy - JConcepts - Airtronics
Irony- Racing Nitro requires more Batteries than Racing Electric.
www.NCTracing.com
i1justin is offline   Reply With Quote
Old 01-26-2011, 10:58 AM   #108
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
Hey keven,
had a question about TC5
I rebuilt my shocks and put new associated rubber bladders in them. I had one that leaked and i took the bladder out and now i cant get it back in. Looks like the bladder expanded. Do you have a suggestion on what i can do to get these bladders to work, or another bladder that i can replace these with?
Also do you have any suggestion on FDR for the new D3 17.5 for the Touring car boosted stock class? Im assuming your running a LRP setup but maybe you've heard guys talking about them. Ive tried a 4.0 and a 7.0 and am currently at a 5.85 FDR, but just doesn't have enough top end, and running temps around 170*. Im one click of timing on the motor, Im running a mamba Max Pro ESC with 45* timing, and my ramping rpms on the speedo are 3500-7000.
Also do you have a suggestion for more highspeed steering. Im having trouble on the TC5 pushing real bad at the end of the straight on "off power" turn in. already at 7mm front and 5mm rear droop.
thanks
bagged69chevy is offline   Reply With Quote
Old 01-26-2011, 02:57 PM   #109
Well my 12th car happens to be an AE 12R5.1 powered by an LRP SSX v2 and LRP 4.0 motor!
Old 01-27-2011, 02:46 AM   #110
Originally Posted by bagged69chevy View Post
Hey keven,
thanks
Put HB tc cyclone bladders. They are black, part number: 73523.
But use them only in TC5 shocks, for TC6 when you switch, they are a little
too small.
For tc6 I put kyosho v-one rrr
Regards!
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 01-27-2011, 09:27 AM   #111
Trader Rating: 114 (100%+)
Good Luck at the 'Birds Keven!
Chris Furman is offline   Reply With Quote
Old 01-27-2011, 01:29 PM   #112
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey kevin i am patiently waiting for my tc6 i wanted to know who makes the all black setup board i always see in your pit? im looking for one. thanx and good luck at the birds!!
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 01-29-2011, 06:46 AM   #113
Default Base tarmac setup
Hi Keven,
could you share with us your base tarmac setup for please?
Thank you.
Marco.
lynx75 is offline   Reply With Quote
Old 01-29-2011, 07:56 AM   #114
Default Special piston?
Originally Posted by STLNLST View Post
Kevin- Are you running your special drilled pistons on carpet as well?
Hi Keven,
How do you do it exactly and what is the benefit of it?
Thanks in advance!
Alan
seasons29 is offline   Reply With Quote
Old 02-02-2011, 11:06 AM   #115
Originally Posted by Apple Guy View Post
Keven,
Now that the SXX Stock Spec V.2 is being released to the distributors, can you give a little feedback on how it ran for you in testing, how it compared to the MKIII and MKIV versions, as well as how it works for modified if you tried it.
Do you feel comfortable that the cogging, as well as all other issues with the previous versions are a thing of the past?
Thanks!
So far, testing has been very good, the new esc feel very good the brakes are very consistant and I am convinced that all the problems we had before are now gone
Originally Posted by BigDogRacing View Post
Hi Kevin, Could you elaborate on why you think the 1.0,1.0,1.5mm piston hole setup works better for you than say 1,1,1? More specifically what do you like better as far as how the car "feels" on the track?
Thanks in advance
the 1,1,1.5 are an in between of a 56 and 57 from losi ! They seem to be better on hight bite since on high speed travel it seems to have more pack and keep the car flatter. but I have also been running them on low bite as well.
Originally Posted by Blue Screw View Post
kevin
when u race1/12 asphalt whatfoams do u use.. and do u use different componds in mod an stock.. also what traction compound do u use and how do u apply it
I have only raced 1/12 once on asphalt but when I did I ran pink rear and magenta front. I ran Paragon ground effect 30min rear and 15 min front ! If I was to run stock I would probably start with the same combination.
Hey sexy,
Hello sexy ! I have been running the 12.0 works rotor !!!
Hi Kody,
I have not had any issues with the stock bearing yet I havent been using ceramics ! I heard some people were having bearing blowing up but I have not had one go bad on me yet so they are definitely not a must.
Hey keven,
thanks
the bladder used in the tc5 shocks would expend after a while ! they need to be replace more often ! you can also run the hotbodies as mentionned above or change them more often.
As for the gearing with the mamba unfortunately I have no idea. 5.85 seems like a fair starting point if I go of my lrp but it is hard to say.
As for more high speed steering , I would try and add more rear droop and less front, also you could try adding more weight to the rear of the car.
The board I have been using is simply a black piece of melamine with a black trim around it ! I have been getting it from a friend of mine who does kitchen counters and stuff like that.
Originally Posted by lynx75 View Post
Hi Keven,
Thank you.
Marco.
Hi Marco,
the closest setup to what I have been running on asphalt is the setup on rc10.com from the 2010 IIC. that is what I would start with.
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 02-02-2011, 12:38 PM   #116
miller tyme's Avatar
Edit just caught your post on the Grandslam Thread
See you there.
Ken Miller
RC America - X-Ray - ORCA - EA Motorsorts - Pro Level RC - Sanwa - TQ Wire - ProOne Racing Tires -
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 02-02-2011, 02:29 PM   #117
Hi Keven!
You still use HB cyclone double joint axles at front? Like in tc5?
Do you do some mod to steering block?
I put bd5 and I need to move inside bearing (it is easy to do), but got
info that spec-r not live long time in fast class.
Regards!
m
Michal Abramowicz
Old 02-02-2011, 02:56 PM   #118
Thanks for the reply Keven!
Shoot I thought you guys were running the stock rotor with the 4.0. How will the stock rotor out of the 4.0 work? Anyway I will order the works 12.0. Just sucks as its not going to be in the motor for a practice day this weekend.
Old 02-03-2011, 12:25 AM   #119
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
Kevin,
Any word on an Associated gear diff?
Are you running the stock front CVA Axles? I am finding I get some binding and vibration in the CVAs depending what my dual rate is set at. What do you do to fix or deal with this?
Thanks,
Troy
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
Old 02-04-2011, 11:36 AM   #120
rosko's Avatar
+1 on associated making their own gear diff
rosko is offline   Reply With Quote
