Old 01-04-2011, 06:33 PM   #76
u use the same 6 degree c-hub slike christian and juhu do?
its more turn inside the corner isnt it?
thanks so far
thilo-alexander is offline   Reply With Quote
Old 01-05-2011, 12:02 PM   #77
JeremyP's Avatar
Is there any difference in having the steering knuckles upside down compared to the TC5 and if so which way do you have them?
JeremyP is offline   Reply With Quote
Old 01-05-2011, 04:32 PM   #78
b-man777's Avatar
Hey Kevin: I've heard that the AE 10R5 has been discontinued is this true and if so why. Also is AE still committed to 1/10th oval? Thanks and good luck in 2011
b-man777 is offline   Reply With Quote
Old 01-10-2011, 02:40 PM   #79
geeunit1014's Avatar
Hi Keven,
Once again congrats on sweeping your classes this weekend, you were on fire for sure
My question is, my car this weekend was really good on brand new tires (1st run), and every subsequent run the car got inconsistent, it was getting a lot of front traction and rotating around the front end. What would you think about changing to keep this in check? I know you said early on you were fastest on 10 run tires (maybe not so many ), but still.
Thanks,
Mike Gee
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 01-10-2011, 03:04 PM   #80
haywood's Avatar
Trader Rating: 48 (100%+)
WGT is not popular around our tracks at all anymore.
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 01-10-2011, 03:31 PM   #81
Buckaroo's Avatar
Originally Posted by Keven H View Post
So far on asphalt I like the LTC the most and on carpet I run the speed6 because it seems to be the most consistant and easy drive.
What have you done to the car to get the speed6 to fit? I can't seem to get it to fit on the front posts unless I put about 4mm worth of shims under the body post.
How far out around your tires to you trim?
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 01-10-2011, 06:40 PM   #82
Trader Rating: 47 (100%+)
Send a message via AIM to smitty2802
I know i'm not keven... but i think he uses the trinity body mount peices...
I'm sure he'll be sure to tell you but it's somthing you could look into untill he verifies that.
-DC-
~Jconcepts~EA Motorsports~
smitty2802 is offline   Reply With Quote
Old 01-10-2011, 06:56 PM   #83
EJF
EJF's Avatar
Trader Rating: 37 (100%+)
Any tips to get consistant TC5 shocks, such as getting the rebound perfect. I noticed on alot of setup sheets some are drilling a hole in the cap, is this in the plastic or metal part?
EJF is offline   Reply With Quote
Old 01-10-2011, 07:06 PM   #84
trerc's Avatar
Trader Rating: 89 (100%+)
Plastic, turn the black plastic cap over and look up it it, you'll see a dimple, that's were you drill your hole.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-11-2011, 06:43 AM   #85
Originally Posted by BlackedOutREVO View Post
Keven,
Sorry I know this has been asked, but im still confused on the whole 1,1,1.5 piston. Do you run that piston on all surfaces? From high grip to low grip, carpet and asphalt? Or what conditions would you go away from that piston?
Hi, Yes lately I have been running there everywhere on both asphalt carpet, high bite low bite !
thanks so far
Yes I use 6 degree castor block ! I like to run them as I can get in the turn harder it wont be as responsive as let say a 4 degree but middle out will have more steering.
I havent been playing much with that I run mine the way they are on the tc5 ! I feel like with 6 degree castor it gives you the right amount of bumpsteer so I havent gone anywhere else.
Unfortunately I don't have an answer for that but I doubt it I will try and figure it out for you. Sorry I am not much help on that one
Originally Posted by geeunit1014 View Post
Hi Keven,
Thanks,
Mike Gee
Hi Mike,
thanks, it was good seeing that both of you guys made it ! I actually ran the same set I had from the last grand slam round at the race until I felt like they were going to rip on me and then put newer one on and did not feel much difference in laptimes ! the older seemed to have more traction but laptimes were to same. On new tires (sweep) the car will push a little more so it may explain why you were doing ok on new tires ! maybe your car had too much steering. The one thing I would do to calm it down and make it more consistent is raising the front roll center and thicker front shock oil ! Or as simple as having less front camber
There is actually 2 front body post ! the one in the kit are a little small ! but I think the one from the ntc3 or 12l4 are a little longer I have to see which one it is I am really not sure ! But otherwise shim under the post will work good as well.
When I ran my tc5 shocks I would drill a hole in the black plastic cap to make sure the rebound was the same ! It doesnt have much rebound its actually dead but that way they are all the same and it seems to be the most consistent way of doing it !
hope this helps.
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 01-11-2011, 07:10 AM   #86
Hi Keven!
I'm going drive tc6 with your setup but with protoform mazda 6 body (no speed6).
What can go wrong?
Probably I will get ltc-r for Saturday spec (no vt speedo/13.5T speed passion) race but it is on way to me ...
Regards and good luck!
m
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 01-11-2011, 09:05 AM   #87
Buckaroo's Avatar
AH, got it. The 4535 posts are taller and solve any body mount problems! Thanks.
Tom Keith
Old 01-11-2011, 08:49 PM   #88
Hi Mike,
Hi Keven, I didnt have much front camber (ended up on 0.5* I think). I did try just a higher roll center in practice, but it did make the car a bit tippy. Maybe it needed the thicker front oil as well to slow the rolling back down? More ideas to try for next time, thanks!
Mike Gee
Old 01-12-2011, 07:15 AM   #89
Hi Keven!
Do you remove some screws from top deck for more flex?
Regards!
m.
Michal Abramowicz
Old 01-13-2011, 02:26 PM   #90
b-man777's Avatar
Hy Kevin: Thanks for the response useful info. I guess we're getting to watered down in on road racing with so many classes. Also no matter what trends come and go in the r/c hobby 12th pan car always seems to survive. Thanks
