Old 01-04-2014, 04:41 AM   #721
jpx
jpx's Avatar
Hey Keven,
thanks for your reply!
I think one can't take it for granted and it's really good to get help from somebody who understands AE cars very well!
Thanks a lot and good luck for all races waiting for you in 2014!
update 01-08-14:
Sorry - I need to bother you with one more question:
What's it all about the position of the different cam-holders: what for do I need "low", "mid-low", "mid-high", "high"?
What benefit do I get if I place the diff up or down etc.?
Jan-Peter
jpx is offline   Reply With Quote
Old 01-08-2014, 09:26 PM   #722
rc car guy's Avatar
hey Keven, I put your 6.2 set up on the ae website on my car and it worked great, my only thing is, could you PLEASE put it on a 6.2 set up sheet because its fairly difficult to follow some of the parts, and id like to see if i have done it properly
rc car guy is offline   Reply With Quote
Old 01-09-2014, 08:42 AM   #723
rosko's Avatar
Hey kevin can u explain some of your setup as to why u decided to go with ... short wheelbase, short camberlinks, shock stood up all the way in back.
rosko is offline   Reply With Quote
Old 01-10-2014, 11:44 AM   #724
Carl Giordano's Avatar
Trader Rating: 23 (100%+)
Hello Kevin,
I could not find the forum for Reedy Sonic Motors, so perhaps you can help. What are the differences i between the Reedy Stock Rotors #954 (12.3x24.2) & #955 (12.3x25) High RPM / high Torque?
thank you
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 01-10-2014, 01:17 PM   #725
Rick Hohwart's Avatar
Originally Posted by Carl Giordano View Post
Hello Kevin,
thank you
Both of these are higher RPM rotors with the 954 more RPM than the 955 due to less magnetic field strength. The 956 comes in the motors (12.5 x 25) which is what I feel is the best rotor for most applications. If your track is not running rules you can run a mod rotor to gain even more power.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 01-10-2014, 05:11 PM   #726
thanks Rick for the response. I'm a loyal Reedy user since '87 and enjoyed the use of the Mach 1 series in 1/12th scale. Now that Tamiya is moving to 21.5 brushless in its Mini cooper class, I've purchased a few Mach 2 motors and rotors to experiment. Mini's are light weight, 1250 grams but fixed geared so I'm considering a high rpm rotor to offset the fixed gearing.
Is there a significant difference between the Mach 1 and Mach 2. Appears its just the alum end bells and smaller front bearing?
Old 01-13-2014, 12:21 PM   #727
whiskyshooter's Avatar
Hey Kevin nice work in Victoria this weekend. Congrats on your double win. When you get a chance can you maybe post up the 1/12 mod setup you used.
whiskyshooter is offline   Reply With Quote
Old 01-24-2014, 11:00 PM   #728
rc car guy's Avatar
When is kevens set up from snowbirds going to be posted?
Old 02-07-2014, 08:52 PM   #729
moparSRT's Avatar
Keven taking the win in 13.5 @ the 2014 SNOWBIRDS
+ YouTube Video
moparSRT is offline   Reply With Quote
Old 03-24-2014, 08:56 PM   #730
Andrew S is offline   Reply With Quote
Old 04-01-2014, 02:49 PM   #731
skyball's Avatar
Good luck in Orlando, Keven!
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 04-06-2014, 06:39 PM   #732
Default 6.1 wc setup question
Hey guys I have a question, I am completely happy with my cars setup except when I get on power in the tighter sections of my track it gets extremely squirly. I am only running 17.5 nonboosted so it shouldn't be getting that loose. Does anybody have any ideas?
Here's my current setup.
37.5 wt shock oil front and back. 40 wt in rear diff, front spool, silver springs f&b, rear position 4c&. Front is 2c. 1degree front toe with - 2 camber., rear is - 2 camber and - 2 degree of toe ( I think, I'm running whatever stock is)
Does anybody have any suggestions?
Bgilli26 is offline   Reply With Quote
Old 09-07-2014, 06:03 PM   #733
Have you tried TC5 rear arms as they are the same length as the TC6.2 front arms may help.
Surrey is offline   Reply With Quote
Old 09-07-2014, 07:09 PM   #734
RielTime Racing's Avatar
Check the rear outer bearings. It's possible that they are worn out. For some reason the rear inner bearings last a little better but would recommend replacing all four rear bearings. Staying off the boards or getting punted into the boards will help with prolonging the life of the bearings.
RielTime Racing is offline   Reply With Quote
Old 09-19-2014, 10:50 AM   #735
More rear tow in (no more than 3 deg) might help. The diff oil is a little light I think the car could be diffing out so perhaps heavier fluid (start with 1000).
www.reedypower.com
