Old 10-23-2012, 02:23 PM   #511
20967's Avatar
I have posted this question also in Mp and Here.
Hi keven, no problem.
For the shocks I do the same thing but I use the Tamiya blu o-ring and I am satisfied for the work with 450 MuchMore oil. Now I am testing Tamiya shocks to see the difference between the original TC6.For gear diff. some tips? Building, oil, grease and so on.
For your set-up I am not able to see this in the IIC website, can help me?
Now solved in "Team Associated TC6 Thread"
Thks
Enrico
20967 is offline   Reply With Quote
Old 10-23-2012, 03:58 PM   #512
rosko's Avatar
Kevin what difference do u feel runing your shock bottoms in the b hole compared to outer c hole?
Why did you run kickup?
rosko is online now   Reply With Quote
Old 10-23-2012, 04:11 PM   #513
gom
[QUOTE=Keven H;11359649]Hi Gom,
You will need to cut the sharp edge but very very little and is easier done with a exacto knife. You will also need the hex like with the RSD.
got it. thanks Keven.
gom is offline   Reply With Quote
Old 10-23-2012, 04:47 PM   #514
B00t13g's Avatar
Do you by chance have a good starting setup for 1/12th 17.5 at mikes? Ill be picking up mine shortly and have never driven 1/12th scale.
B00t13g is offline   Reply With Quote
Old 10-24-2012, 03:12 AM   #515
H I
H I's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Keven H View Post
Hmm both motors are very good motor. the feel is slightly different, with the LRP motor having more torq and Reedy being smoother. I think you can get close to the same runtime with both motor from my previous testing. One of the main thing that helped me with effeciency and runtime was going to the Flow ESC. I was very surprised at how much cooler and faster the ESC was from what I had before. But I never ran into much issue with runtime with the 6500 battery before tho, I cam close a few times but it didnt seem much of a problem. I dont think .0 are more efficient. I think it has a lot to do with ESC settings, sometimes when they are wrong, it can be slower when the timing is too much and it doesnt reach it and therefore it will also drain more batteries so also something to take into concideration. But I think both motors are great and you can find what you like with either one of them with some testing, gearing and ESC.
Hope this helps, and let me know if you have any questions.
Thank you, I just bought Reedy 4.5 and 5.0
H I is offline   Reply With Quote
Old 10-24-2012, 01:14 PM   #516
Thks
Enrico
Hi, When I build my gear diff I just put everything together like the instruction and once in a while probably every 3 race meeting, I will change the orings and gear to make sure the diff is always in good shape because the oring tend to swell and makes the diff feel thicker. As for the setups, they are posted on www.rc10.com under setup.
if you are talking about front and rear, going to the B hole front and rear will usualy make the car a little agressive. the car will feel like it rolls more and I have found the car to be more stable on high grip condition in the C hole. The main difference for me was in the sweeper with the C holes the car did not want to dump over and felt like it carried more corner speed.
This will be just a guess since I have never run 17.5 1/12 but if I was to run the class I would start with the IIC mod setup and probably silver side spring and Black and yellow for tires and that should be a good starting point ! hope this helps.
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 10-24-2012, 04:41 PM   #517
Logi Maker's Avatar
Trader Rating: 49 (100%+)
The Howart (Hebert's) setup from world's is dialed.... your rollout, depending on motor will be between 95-105... I am at 104mm with a reedy sonic.... you're going to love it!
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\Schelle
Logi Maker is offline   Reply With Quote
Old 10-24-2012, 10:55 PM   #518
TEAM BURN's Avatar
whats a good size and spur to start with for 17.5 1/12? thinking i might run 17.5 at the TZGP
"Crazy" Mike Najdychor
XRAY T4 / LRP FLOW / LRP X20 5.0
AE 12R5.2 / LRP FLOW / LRP X20 4.0
2 sec faster
I Drive Mod :)
TEAM BURN is offline   Reply With Quote
Old 10-24-2012, 11:31 PM   #519
TEAM BURN's Avatar
Thank you, when you get the car, nothing major is needed except the Dual joint for the front when running on carpet is a good option to have. I run the Tamiya one from Spec-R but I beleive the Yokomo are a good fit has well but you need 5mm hex with any dual joint you will use because stock AE hex wont fit.
Everything else should be going together well and you should be good to go.
For 1/12, if you do run mod, I would not go any bigger than 42.5-43mm in the rear to start with and 40.5 front to get about 5 runs on them. problem is when running modified now the cars are so fast that tire wear can be an issue. I run mine down to 38.8mm but thats as low as I will go for front and 40.8 for rear.
Good to hear you will be at timezone GP. Looking forward to meet new people.
thanks Keven that helps! on your setup sheets for tire size f39.5/r41.5, would that be your last run?
2 sec faster
I Drive Mod :)
Old 10-25-2012, 12:46 AM   #520
B00t13g's Avatar
Thanks keven, ill give it a shot!
Thanks man! I'm pretty excited to build and try 1/12 for the first time! Ill be using a reedy 17.5 and an Orion r10 I THINK. Do you have any recommendations on a good servo?
Old 10-25-2012, 04:13 AM   #521
Logi Maker's Avatar
76 is the most common with pinion range 57-63.... the TZGP will be epic!
The Futaba 9650 is the most popular.. I am running the Savox 1350 with no issues.....
Ok, thread is all yours Keven.... see you at the GP!
Kyle Predmore
Old 10-25-2012, 05:08 AM   #522
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Hi Keven,
Hope all is well, I was wondering if you have a starting setup for the 5.2 On asphalt? Also, are you going to TITC again?
Thanks,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 10-25-2012, 10:00 AM   #523
20967's Avatar
[QUOTE=Keven H;11363967]
Thks for info.
Enrico
Old 10-29-2012, 12:57 PM   #524
Francis M.'s Avatar
Hi Keven, how do you determine which body you'll be running when going to a new track... LTCR or Mazda?
Francis M. is offline   Reply With Quote
Old 10-29-2012, 05:23 PM   #525
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Kevin,
I was wondering how you go about setting your droop? Also, what is the preferred method when saucing tires for carpet racing?
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
