Old 02-18-2012, 10:03 AM   #391
What setup do you recommend to start with on low/medium bite carpet? (using sorex 28 tires)
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 02-18-2012, 03:56 PM   #392
tc6.1 setup from manual
in shocks pistons 1/1/1,5mm and oil front 55wt, rear 50-55wt
maybe rear spring green if traction is low, if go up, put silver.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 02-19-2012, 06:26 AM   #393
Hi keven,
So mean there no way to update a v1 esc to v2 esc with the bridge? Then any other way to make my v1 to v2? That's mean the bridge I buy is wasted.
~Team Associated AE TC6~ Disable
~Team Associated AE TC6.1~ SOLD
~Team Associated AE TC6.1WC~ Retire
Switching to YOKOMO ~Yokomo BD7~
**Swan Radio Control Club (SRCC)**
icefish is offline   Reply With Quote
Old 02-19-2012, 07:10 AM   #394
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by icefish View Post
Hi keven,
http://www.lrp.cc/en/news/news/produ...b20818ab890745
With the new LRP Logicboard, you can update V1 to latest spec.
From now on, Modified- and Stock drivers have a common goal when it comes to brushless speed controls. To get your existing SXX speed control version 1 and version 2 up to the new Champion’s League, LRP releases the brand-new Upgrade-Kit SXX „Mod + Stock“. It fulfils the requirements perfectly of both classes and still offers enough possibilities for individual adjustments. The new kit was completely developed from scratch. Hard- and software can no longer be compared with the previous version. E.g. the new linear BEC is considerably more stable. The adaption of the voltage to the BEC as well as to the controller, make the overall system faster and more resistant against malfunctions.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-19-2012, 07:58 AM   #395
Jochim_18's Avatar
How's much is this upgrade?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 02-20-2012, 03:36 AM   #396
Thanks buddy, I will look for it in my local market
Old 02-21-2012, 12:40 PM   #397
Geberit's Avatar
Hey Keven,
how do you measure ride hight? Do you just drop the car on the set-up bord or do you tapp/push it a little down to settle it? I get different resulti: 4,5mm with the first method and almost 6mm with the other!
Geberit is offline   Reply With Quote
Old 02-21-2012, 12:53 PM   #398
hanulec's Avatar
Trader Rating: 27 (100%+)
Hey keven - have u given Haynes the right setups forbhisncars yet? Or do unwanna watch him fail for a while first??? Feel free to point him in the wrong direction for a while . It will be fun to watch
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-21-2012, 01:40 PM   #399
It is posible to get picture how right set "drop" value for tc6.1?
in ae drop = downstop
regards!
Michal Abramowicz
Old 02-22-2012, 12:26 AM   #400
Default need some advise
Dear Keven, need some help on coming competition on may at my place. Please check the picture and give some advise, i need gear ratio advise, ESC setting, tayar and insert ^^
take note, this will be a concrete remix track with some paint on it (something like badminton court) i'm using LRP SXX TC spec V1 ESC with LRP 4.5T octa wind motor. The longest speed way(the speeding straight way) for this track will be around 200feet excluding the corner for both side.
another asphault (a bit bumgy) track for normally i pratice and play fun will be as follow, same i need the great ratio, ESC setting and car setting from your seggestion, thanks.
p/s: the longest speeding way will be 140 feet excluding both side corner, thanks.
Old 02-22-2012, 06:22 AM   #401
Originally Posted by Keven H View Post
Step 5 I set my car on the edge of the board * so the middle of the chassis hit the edge and then make sure both tires hit the board at the same time to make sure the droop is even (if the chassis is flat and you dont have a crazy amount of slop it should be work very good ! I do that front and rear and while doing this, you want to tweak the car at the same time ! so to do the front you hold the rear and push up on it until front tires hit the board and then you will see if the car leans over on the left or the right which ever side leans first you need to put more preload on that side an a little less on the other side !!! The you do the same for the rear ! I am reading it and know it might be hard to picture but it is the best explanation I could get for now
Sorry keven, I'm not very understand start from setp 5, can you explain in more simple way? Sorry for inconvenient .
Old 02-22-2012, 06:47 AM   #402
Trader Rating: 38 (100%+)
regards!
I was wondering the same thing.
or8ital is offline   Reply With Quote
Old 02-22-2012, 07:36 AM   #403
I ask because there is hm... some plastics on arm and ... where take this dimmension????
Just wonder.
Michal Abramowicz
Old 02-22-2012, 10:45 AM   #404
just buolt the car and first test will be at a race this weekend, i wonder the same thing.. for now i followed the picture in the manual, it looks like the measurment should be just under the screw that blocks the hinge pin..(?)
Old 02-22-2012, 11:17 AM   #405
Big Features's Avatar
You are correct, regards!!
Mike Kling
Team Associated • REEDY Powered
JConcepts • TXD Skin Graphix
Big Features is offline   Reply With Quote
