Old 01-14-2012, 12:00 PM   #361
infokiz's Avatar
Originally Posted by Infinite 12th View Post
I can't find the xceed putty diff on the net but would this work fine
http://www.tqrcracing.com/shop/produ...+putty&pg_no=1
Anyone have the xceed link for the putty?
Or just get the artist kneaded rubber ...lol
Here you go...
http://www.amainhobbies.com/product_...ing-Putty-100g
infokiz is offline   Reply With Quote
Old 01-14-2012, 12:52 PM   #362
Infinite 12th's Avatar
Originally Posted by infokiz View Post
Thank you
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 01-15-2012, 10:22 AM   #363
Thank you
xceed or Spec will work ! what you want to do is put the first gear in but small amount a a time put it as much as you can as long as the other gear will fit in and then put the middle gear, then put more en then close it and it should be good.
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 01-16-2012, 04:45 AM   #364
Geberit's Avatar
Hallo,
A quick question regarding Cam holders. What is the difference in using the higher numbers (17-32) or lower numbers (1-16)? OK the diff is higher or lower so the weight is higher or lower. Buth other than that? Can I get some different handling?
Geberit is offline   Reply With Quote
Old 01-16-2012, 08:33 PM   #365
rcscoot2539's Avatar
Default springs
Hey Keven, I see on your set-up sheets you say you are running Yokomo pink - blue springs what spring rate are they? Thanks
TC6 - B4.1 - LOSI SCTE - LRP - SPEKTRUM - SWEEP - AB CHARLES HOBBY SHOP - THE RACEWAY AT BEAVER
rcscoot2539 is offline   Reply With Quote
Old 01-16-2012, 10:49 PM   #366
clparsons123's Avatar
Hey keven
What is a good starting point for 17.5 boosted touring with a lrp ss v2 and reedy sonic motor? Settings and gearing pleaseA
Thanks cory
EAM (TEAM EA MOTORSPORTS),ORCA, RC AMERICA, XRAY,HUDY,EZ CUSTOMS, RSD (REFLEX RACING) , JEFFS RC STUDIO, RCTVLIVE
Cory parsons
clparsons123 is offline   Reply With Quote
Old 01-17-2012, 01:41 PM   #367
Jay7's Avatar
Send a message via AIM to Jay7
Keven thanx for showing me that method on tweaking my TC in New Rochelle last week. Been using it and I feel a difference. Good luck at the Snowbirds!!
Jay7 is offline   Reply With Quote
Old 01-17-2012, 02:57 PM   #368
Originally Posted by Geberit View Post
Hallo,
running the notches up 1-16 will make the diff lower and running the notches down will make the diff higher. I have found to like the diff lower 99,99 percent of the time and stick to it. diff height will change the way the car handle. in some case we run the front diff higher to help the car get out of the turn and it will give you a bit more steering. It has been a long time since I have played with diff height but I when I did I have always found the mid low position to be the best in most case.
I beleive the pink is 14.? and the blue is 12.12.***BUT*** the pink has more coil than the blue so they feel very similar when you compare them since one is more progressive than the other.
Originally Posted by clparsons123 View Post
Hey keven
Thanks cory
Hi Cory,
I beleiver I ran 0/10/8/1 last time I ran with stock rotor 36/106 and 25 degree timing ! I assume this is for Snowbirds ? I am almost positive this is what I found was best few weeks back when I tested but just come see me at the birds and I will help. keep up the good work
No problem, my pleasure glad I was able to help. Good to see a big group of guys running in new rochelle and keep it up, you were running very good for the short amount of time you been doing it.
Keven Hebert
Old 01-17-2012, 04:27 PM   #369
CraigM's Avatar
Trader Rating: 34 (100%+)
Which method is that?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 01-17-2012, 09:44 PM   #370
Thanks for the reply keven . Yes I am going to run birds . I tried the lrp for the first time this past weekend at boylans mennreg race and I really liked it . My settings were pretty close to what you said .thanks for the help I will come see you at birds
Cory parsons
Old 01-31-2012, 05:37 PM   #371
nicorozog's Avatar
Send a message via MSN to nicorozog Send a message via Skype™ to nicorozog
Default 10.5 boosted
Ey keven can you give some advice to 10.5 Boosted class using LRP SS V2, with Reedy Sonic 10.5....
Thanks!
nicorozog is offline   Reply With Quote
Old 02-01-2012, 05:06 AM   #372
Keven,
it is posible to put your tc6.1 car on weight scales each corner?
And share how many grams is at front under tire and rear end?
Car ready to run.
Thank you
m
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 02-01-2012, 11:36 AM   #373
Default Gear diff
I am using a 2 Millions CST sillicone oil. It is very effician.
I think it is more mecanical than filling with putty !!!!!
Regards
PS : 2 M cst oil is available at SMS shop in France.
fredB is offline   Reply With Quote
Old 02-04-2012, 01:28 AM   #374
Geberit's Avatar
Hi Keven,
I see you cut your top deck a little, do you get more flex with this?
I was reading someone was cutting the shock towers in half to get more chassis flex. Do you think this is a good idea for low traction surface tracks or did you maybe tried it yourself?
Old 02-04-2012, 07:28 AM   #375
S_fender's Avatar
Hi Keven,
Hello,
Where did you see that ? A pics ?
Thanks.
S_fender is offline   Reply With Quote
