Old 09-03-2011, 07:09 AM   #301
Big Features's Avatar
Ask Keven Hebert, TeamAssociated / Reedy / ApexRC-photo-3.jpg
Here is my 12R5.1 Lipo Conversion.
I like it VERY much. Very fast and easy to drive.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 09-03-2011, 10:07 AM   #302
Originally Posted by Big Features View Post
Attachment 803397
Mike
Do you get the same weight from a 1s and all the electrics?
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 09-03-2011, 10:39 AM   #303
Infinite 12th's Avatar
Attachment 803397
Mike
Looks good
If anything what was first thing you noticed from other configuration regarding battery?
Apparently these are things web page says it is different because
The RC12R5 chassis has been optimized for 1S LiPo batteries, with the following additional enhancements:
* Inline battery positioning generates a lower polar moment of inertia for smoother mid-corner steering in high traction conditions
* Lengthened wheel base for added stability
* Front bulkhead mounting position widened to give more options for upper control arm length and added adjustability for multiple track and motor conditions
* Updated rear upper pod geometry increases leverage on center shock to help compensate for the lighter minimum overall chassis mass when using LiPo batteries
* Stronger blue aluminum chassis braces
* Thicker 3mm rear chassis brace gives extra support for rear body posts ad side springs
Infinite 12th is offline   Reply With Quote
Old 09-03-2011, 10:53 AM   #304
The 1st thing I noticed was how forgiving and easy it was to drive. It carried good speed without feeling edgy.
Mike Kling
Old 09-03-2011, 09:02 PM   #305
Cool
Look forward to some results outdoor and maybe some setup sheets
Old 09-06-2011, 08:09 AM   #306
Originally Posted by bunny32 View Post
hi kevin im a rookie mate i just need some help on one of ure setup sheet at may the 1st wcrc raceway high grip asphalt ure camber is it + or - on the front and rear and bumpsteer tall ballstud what is that what do they mean thanks kev im vince
Hi, the camber on any setup sheet should be negative. For Ballstud, there is 2 kind of ballstud associated offer, one of them is short and the other one is taller by .030. The black one are always short and silver one are tall. Let me know if you have any questions
Originally Posted by Infinite 12th View Post
Thanks I sent you a pm
I am excited about the new inline also
See ya
p.s. Have they changed things in this "latest production kit"?
The one I had been running last year had a bigger top plate on only one position for the shock mount. The new kit has a different geometry for the center shock.
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 09-06-2011, 08:30 AM   #307
Default hi
thanks kevin but did u put a washer on there aswell with a tall ballstud and where did u mount the other side of the steering link on i mean on the bulkhead or the shock tower where the holes are. one more thing do u r short wheel base or lenghten wheel base cause on the set up sheets u have 1 mm wheel base
bunny32 is offline   Reply With Quote
Old 10-13-2011, 02:51 PM   #308
Sorry I have been slacking here lately but I plan to be back in the game ! I also wanted to let you know that the setups I ran at the IIC last week are now on AEs website here is the link : http://www.teamassociated.com/setupsheets/
let me know if you have any questions
Keven Hebert
Old 10-13-2011, 03:01 PM   #309
jag88's Avatar
Hi Keven, I tried the 1,1,1.5 pistons and I find them to be really soft especially with the oil you suggest. I had to run 70 wt oil just to get the the feel I was used to. The only thing I can think of is that our track has WAY more bite then the tracks you run on plus I think you have to use Jaco blues at most big races. Any thoughts ?
Thanks.
jag88 is offline   Reply With Quote
Old 10-13-2011, 03:22 PM   #310
Thanks.
Hi,
It is a little softer than let say 56 for sure but I like running my car pretty light it changes direction quicker ! I am pretty sure IIC had quite a bit more traction than MSI so I don,t think that would be an issue but with sorex tires the setup could change a little bit ! I assume you can try a little heavier oil but I am prety sure I would not go any more than 10wt more then what I posted.
Hope this helps.
Keven Hebert
Old 10-13-2011, 06:17 PM   #311
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thanks Kevin.
In the front suspension notes... what does "2mm on top upper arm" refer to ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-13-2011, 06:19 PM   #312
fatbear's Avatar
Send a message via Yahoo to fatbear
Hi Keven,
I run on a low grip carpet track in mod with my TC6. We are not allowed any traction additives of any sort.
What changes can you recommend say from your IIC mod setup to allow for these conditions?
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 10-13-2011, 07:37 PM   #313
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey RedBullFiXX,
I think what Kevin means is where the caster block mount's to the aluminum arm mount you can put a shim in between there. Also you can add shim's between the lower arms and aluminum arm mount.If you do so your going to have to take off the Graphite brace.
Hope this helps
Originally Posted by RedBullFiXX View Post
Thanks Kevin.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 10-14-2011, 03:53 AM   #314
Default Shock oil
Hi Kevin,
I have a technical question. What hot girl will you be bringing to the Halloween Race?
Thanks,
A fan
windix606060 is offline   Reply With Quote
Old 10-14-2011, 06:08 AM   #315
Originally Posted by mike ivy View Post
Hey RedBullFiXX,
Hope this helps
Thanks Mike
