Old 12-22-2010, 06:26 AM   #16
Timbulb's Avatar
Originally Posted by Drew Ellis View Post
I have a question, way do French people spell Keven with a "E" instead of a "I"? Lets all ponder on that for awhile.
Congrats on your new thread bro....
Thanks Drew
Even more puzzling is why Americans spell ketchup "CATSUP".
Timbulb is online now   Reply With Quote
Old 12-22-2010, 08:38 AM   #17
locked's Avatar
Or why Drew seems to always type "Are" instead of "Our"
Some of life's great mysteries.
Keven. Kudos for starting this thread. Hopefully you will eventually get some legitimate questions
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 12-22-2010, 09:10 AM   #18
Originally Posted by STLNLST View Post
Kevin- Are you running your special drilled pistons on carpet as well?
Yes I run the 1,1,1.5 even on carpet
Originally Posted by Owen RaCing View Post
Keven,
What procedures do you prefer to use to set up your car (Droop, ride height, camber, tweak, front toe etc.) Also, what procedures do you take after a run to prep your car for the next?
That is a good question ! Here is how I do it. I go as simple as possible as I dont like to use fency gage, it always seems like the best way for me is the manual way. the first thing I do is I make sure the chassis is flat. Step 2 is I set ride height , Step 3 for me is camber. Step 4 I set my droop usualy by feel 2mm uptravel to start with is what I do on most track front and rear and then adjust from there ! Step 5 I set my car on the edge of the board * so the middle of the chassis hit the edge and then make sure both tires hit the board at the same time to make sure the droop is even (if the chassis is flat and you dont have a crazy amount of slop it should be work very good ! I do that front and rear and while doing this, you want to tweak the car at the same time ! so to do the front you hold the rear and push up on it until front tires hit the board and then you will see if the car leans over on the left or the right which ever side leans first you need to put more preload on that side an a little less on the other side !!! The you do the same for the rear ! I am reading it and know it might be hard to picture but it is the best explanation I could get for now Let me know if you have any question.
Originally Posted by Johnny Wishbone View Post
Keven, I see LRP has now released the USB link for the upgradeable speed controls. Any idea where the download for the software is? Do you have a link?
The software should be available on LRPs website in a few days ! http://www.lrp.cc/
Originally Posted by Mini-Mod View Post
Why is your car the tard car?
Tard car haha ! Long story regarding my poor english back 5 years ago. Had a hard time to say Todd so people were making fun of me since it sounded like tard when I would say it.
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 12-22-2010, 09:19 AM   #19
1fastdude's Avatar
Trader Rating: 15 (100%+)
He He If you take a trip to your grocery store (Krogers) you will see that there are "in fact" to ways of spelling the RED thick tomato condiment:
Catsup
Ketchup
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 12-22-2010, 09:36 AM   #20
Donny Lia's Avatar
Catsup
Ketchup
Also, there is "in fact" only one way the number 2 is spelt, two.
RocheAwesomatixTrinityKoBsrProtoformTQAvidKimbrough
Donny Lia is offline   Reply With Quote
Old 12-22-2010, 09:55 AM   #21
spelled
Pink and Blue is offline   Reply With Quote
Old 12-22-2010, 09:59 AM   #22
Lots of grammar tips in here ! my english will just get better now
Keven Hebert
Old 12-22-2010, 09:59 AM   #23
How do I go fast?
Kyosho / Team Orion / AKA / JTP / Sharkbait Designworks / RC Tracks of Las Vegas
Chris Jarosz is offline   Reply With Quote
Old 12-22-2010, 10:00 AM   #24
Rick Hohwart's Avatar
Hey Kev!
I have not installed a gear diff in my TC6 yet. Which brand do you use and what modifications need to be made to the car and/or diff to make it fit? And in what conditions do you think the gear diff gives an advantage?
Rick Hohwart is offline   Reply With Quote
Old 12-22-2010, 10:08 AM   #25
Originally Posted by Chris Jarosz View Post
How do I go fast?
Eat Chipotle as much as you can
Originally Posted by Rick Hohwart View Post
Hey Kev!
Hi Rick,
I have been running the spec R ! I think the biggest thing with the gear diff is the maintenance. I beleive on asphalt it does give an advantage because it rotates harder but on carpet, It does some stuff better and some worst. It drive a little different out of the turn and might be a little hard to drive on low bite tracks but with some setup changes it is good.
The Spec R will need a little bit of work, it is too wide by about 1.5mm so you need to take some material off the bearing cap ! I shaved the outer bearing by about 1mm on each side where the groove is I just made that groove deeper. Then I dremeled the outdrive of the spec r diff so the bone fits ! its very little ! some people have also sanded the bone with succes too.
Keven Hebert
Old 12-22-2010, 10:25 AM   #26
1fastdude's Avatar
Catsup
Ketchup
He he he he I was hoping someone wood catch my mistake........
Old 12-22-2010, 10:40 AM   #27
trerc's Avatar
Trader Rating: 89 (100%+)
Originally Posted by Pink and Blue View Post
spelled
Touche!
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 12-22-2010, 10:55 AM   #28
would.
Keven, are you going to be at the gate race in January?
Old 12-22-2010, 10:59 AM   #29
1fastdude's Avatar
Old 12-22-2010, 10:59 AM   #30
would.
Yes I will be !
Keven Hebert
