Old 06-20-2011, 09:20 AM   #271
Rick Hohwart's Avatar
I think Keven ir traveling today so I'll answer...
Originally Posted by P.I.M.P View Post
Hi keven
what pistons would you recommend for out door asphalt or should what comes with the tc6 be good enough.cheers
The AE #2 is a 2-hole piston in the kit which works very well. Losi #57 also works well (3-hole). There are various custom sizes as well which can be drilled using AE's blank pistons. Check AE's setup sheets for recommendations.
Originally Posted by mcdomdom View Post
Hi Kevin!
In the Setup from Bob Stellflue at the Reedy Race he wrote that he drives droop 2mm uptravel! What is the meaning of 2mm uptravel in this case?
Thank you and greets
Dominik!
This is measured by setting the ride height (5mm for example) and lifting the car until the tires lift off the setup board. You can measure this with the ride height gauge which in this case should read 7mm.
This measurement allows you to set the droop equally among cars with different tire diameters. The droop gauge setting does not take tire diameter into consideration. A car with larger tires will have more droop that one with smaller tires assuming the ride height and droop gauge settings are equal.
Rick Hohwart is offline   Reply With Quote
Old 06-20-2011, 09:56 AM   #272
Originally Posted by Keven H View Post
Chipotle !!! not even a fight
You sir, are terrible!
Kyosho / Team Orion / AKA / JTP / Sharkbait Designworks / RC Tracks of Las Vegas
Chris Jarosz is offline   Reply With Quote
Old 06-21-2011, 01:23 PM   #273
nashrcracer's Avatar
R/C Tech Charter Subscriber
Originally Posted by burito View Post
4-dot = 27.5
3-dot = 32.5
2-dot = 37.5
1-dot = 42.5
0-dot = 47.5
You read the timing with the dots facing you.
so a 4 with the dots inside as opposed to visible would be 47.5 if you can't find your 0 or are you saying put the 4 in backwards to get 47.5
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 06-21-2011, 02:01 PM   #274
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
There are only 3 inserts.
Flip them over to see other dots.
There is no marking for 0 dot, because it's, well, "0"
4-dot = 27.5; 0-dot = 47.5
3-dot = 32.5; 1-dot = 42.5
2-dot = 37.5; Same both ways
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-21-2011, 04:51 PM   #275
hey keven how was it at jackson nj on sat and what set up did you use
jerry l is offline   Reply With Quote
Old 06-21-2011, 08:18 PM   #276
thanks for clearing that up. I only have the one (4/0) I borrowed out the others to someone that bought a motor used so he could play with the settings and I'm not sure I got them back. ran it with a black diamond last weekend at my track 92x50 with 6.8 fdr and it was stupid fast. x12 is the best motor for boosted as far as I'm concerned.
Old 06-25-2011, 02:57 PM   #277
Salut Keven
Tu a le bonjour d'un cousin de France.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 06-26-2011, 09:49 PM   #278
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
Hi keven
do you have a way to stop the arm mounts moving im swing off the screw to get them tight and still moving after a run.cheers
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 06-27-2011, 04:18 PM   #279
Hi Kev!
I see that you change a little your setup at front.
Still use 6 deg c-hub but Y change from:
FWD RWD
0B 1B
to:
3A 0B (from 6 deg to about 5, info from J.L.)
Basically it lower RC a little, but changing castor value is the same?
I ask because in my case I still wait for replacement for broken by manufactory bulkhead ... and I cant use A hole
Regards!
m.
ps: see you in Germany ETS
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 08-23-2011, 02:30 PM   #280
Just wanted to post here and bring the thread back since the carpet season is not too far away if you have any question feel free to ask !
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 08-23-2011, 04:20 PM   #281
cwoods34's Avatar
I ran a Novak 5.5 40ish timing (until I can get an LRP) on my SXX v1 on Profile 10, and it was stupid fast. I had the gearing in the high 6's and temps didn't come over 130*F. I was just curious as to how much literal timing/boost the SXX adds on Profile 10? Or if you could tell me how much more each increase of "1" adds, as in the manual saying profiles 4 and 5 are +1, 6 and 7 are +2, etc.
First weekend with the TC6 and I love it! Great mod car, very easy to drive
Hope to see you back at R/CAR sometime this season!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 08-23-2011, 05:35 PM   #282
hanulec's Avatar
Trader Rating: 23 (100%+)
keven - where will you be practicing prior to IIC?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-23-2011, 10:28 PM   #283
RacinJ's Avatar
Default 12R5.1 Lipo
Keven, When will you and the rest on the team be posting set ups for the 12R5.1 Lipo?
AE 12R5.2 / McFactory; Roche P12 '16; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is online now   Reply With Quote
Old 08-24-2011, 01:59 AM   #284
Redwood's Avatar
Hey Keven,
Would you mind sharing your tyre preperation for Asphalt? Do you scrub a new set of tyres on track or on the bench somehow or not at all?
Which additive do you use and for how long?
How do you set the temperature on your warmers and when do you put them on and take them off?
Thanks in advance,
Neal
Redwood is offline   Reply With Quote
Old 08-24-2011, 09:16 AM   #285
al dente's Avatar
kevin, how do you get your hair so rich and full bodied?
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 20-23, 2017
al dente is offline   Reply With Quote
