Old 06-10-2011, 07:00 AM   #256
Xpress's Avatar
Originally Posted by Andrew Gray View Post
Wow Kevin, that's an old picture. That is from the Halloween Classic 2003 at The Gate when it was still upstairs in the ghetto strip mall. Ahhh, the good ol' days foam tire mod touring car when the XXX-S & TC3 ruled the roost
Andrew Gray? Last I heard you were living with Elvis?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 06-12-2011, 02:52 PM   #257
mcdomdom's Avatar
Hi Kevin,
thank you for the answer!
Ive got a nother question: the original belt of the TC6 is verry stiff I think! Do you youse the original belt or gives it something like a low friction belt for the TC6? Maybe from another car or another brand, or will asso bring another belt for the car in the future?
Thank you and greets
Dominik
VBC Wildfire D06, LRP SPX Zero, Thunder Power 13,5T, Reedy batteries!!!
mcdomdom is offline   Reply With Quote
Old 06-13-2011, 06:13 AM   #258
Chris08527's Avatar
Trader Rating: 16 (100%+)
Kev,
heard you might be coming out to JAckson this weekend for the Reg 2/Nats Warm Up???
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 06-13-2011, 10:39 AM   #259
Originally Posted by mcdomdom View Post
Hi Kevin,
Dominik
Hi Dominik,
the belts might be a little tight fresh off the box but they loosen up very quick and with the cam holder having a big selection for tension you can get it loose enough. There is no new belt coming anytime soon. The one good thing about our belt is they last forever.
Originally Posted by Chris08527 View Post
Kev,
Hi,
Yes I will be there all week end long !
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 06-14-2011, 03:25 PM   #260
Casey's Avatar
LRP motor question.
There was a debate in the pits at a local race about the timing inserts for the x-12 based motors.
When installed, should the dots be visible and at the bottom of the opening ?
example 2 dots visible at the bottom when the motor is assembled is neutral, would 4 dots visible when the motor is assembled be maximun advanced timing ?
Casey is offline   Reply With Quote
Old 06-14-2011, 05:08 PM   #261
AE-Reedy
Originally Posted by Casey View Post
LRP motor question.
Dots visible yes, up or down does not matter. The 2 dot insert is the exception does not make a difference which way it is installed. The other inserts will either advance or retard the timing depending on what dots are facing out. As an example, if you look on the back side of the 3 dot insert you will see 1 dot. Also 4 dot equals least amount of timing which happens to be 27.5 degrees.
No charge for the consult Keven.
Sean Cochran is offline   Reply With Quote
Old 06-14-2011, 06:40 PM   #262
xtrememadness's Avatar
Send a message via AIM to xtrememadness
LRP motor question.
casey in blinky run max timing! thats no dot! my motor never got hotter than 195 np for lrp motors!
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 06-14-2011, 07:23 PM   #263
Casey's Avatar
Thank you, what do all the timing dots equal ?
Old 06-15-2011, 07:49 AM   #264
burito's Avatar
4-dot = 27.5
3-dot = 32.5
2-dot = 37.5
1-dot = 42.5
0-dot = 47.5
You read the timing with the dots facing you.
Reto Koenig
burito is offline   Reply With Quote
Old 06-15-2011, 09:09 AM   #265
Nice information, thanks for sharing Reto.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 06-15-2011, 09:31 AM   #266
energyracing's Avatar
Keven, whats better Chipotle of Taco bell?
George B.
energyracing@hotmail.com
Sponsored by Serpent / SRX2 MM, RM, SC / Serpent SRX4
MoFo paints
energyracing is offline   Reply With Quote
Old 06-15-2011, 06:07 PM   #267
Casey's Avatar
Originally Posted by burito View Post
4-dot = 27.5
3-dot = 32.5
2-dot = 37.5
1-dot = 42.5
0-dot = 47.5
Thank u
Old 06-15-2011, 06:18 PM   #268
4-dot = 27.5
3-dot = 32.5
2-dot = 37.5
1-dot = 42.5
0-dot = 47.5
Thank you Sean and Reto for helping out !
Chipotle !!! not even a fight
Keven Hebert
Old 06-18-2011, 11:49 PM   #269
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
Hi keven
what pistons would you recommend for out door asphalt or should what comes with the tc6 be good enough.cheers
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 06-19-2011, 11:30 AM   #270
mcdomdom's Avatar
Hi Kevin!
In the Setup from Bob Stellflue at the Reedy Race he wrote that he drives droop 2mm uptravel! What is the meaning of 2mm uptravel in this case?
Dominik!
