Old 05-29-2011, 09:06 AM   #241
shoe's Avatar
Default Losi piston ?
What is a #57 equivalent to a Associated part. Thanks
shoe is offline   Reply With Quote
Old 06-03-2011, 06:29 AM   #242
mcdomdom's Avatar
Hi Kevin!
It is possible that you post your final Set-Up from the Reedy Race last weekend? Would be fine!
Thank you and greets
Dominik!
VBC Wildfire D06, LRP SPX Zero, Thunder Power 13,5T, Reedy batteries!!!
mcdomdom is offline   Reply With Quote
Old 06-07-2011, 01:32 AM   #243
hi Kev!
what is difference between front:
FWD 3A, RWD 0B, 6deg c-hub and
FWD 0B, RWD 1B, 6 deg c-hub.
If I have it right, that was your 1st setup for tc5 when 0B/1B was on front.
Can you wrote more about your experiments on asphalt REEDY Race ?
Your fan,
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 06-07-2011, 11:36 AM   #244
tsan's Avatar
Hey Keven.
What hair/blow dryer would you recommend I use to get myself ready for a big race day?
Tim Sanderson / tsanrc.com / I ♥ KYOSHO
tsan is offline   Reply With Quote
Old 06-07-2011, 01:20 PM   #245
Gravity RC
Originally Posted by tsan View Post
Hey Keven.
Kevin once told me that this is the only way to go. plus who ever rooms with him gets a good workout every morning helping him. i always wondered why bob is so strong. lol
http://cgi.ebay.com/Antique-Fireplac...item2eb5b6da26
Paul L is offline   Reply With Quote
Old 06-08-2011, 09:38 AM   #246
DARKSIDE's Avatar
Keven ygpm
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 06-08-2011, 10:00 AM   #247
MugenDrew's Avatar
Trader Rating: 30 (100%+)
LMAO
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 06-08-2011, 06:08 PM   #248
Trader Rating: 76 (100%+)
It seems like the more time I spend building this kit the worse it gets, and right now I feel like I'm in the middle of next week. I have tried to build the cva's but had to resort to leaving the set screw out. And now on the fourth and last one (of course, its always the last one), even with the set screw out it still binds terrably. This after not having 4 screws and having issues building the shocks, I must say I'm not really impressed with the TC6 so far.
MUDVAYNE is offline   Reply With Quote
Old 06-08-2011, 07:15 PM   #249
Originally Posted by hacker View Post
Kevin, whats your current setup at the front;
gear diff or spool? if gear, what oil are you using?
also, you have said previously if you went front diff that you would use the standard cvd's. What is wrong with using the xrays ecs with a front diff?
Hi, at the Reedy race I ended up running a gear diff in the front with putty in it ! It is about as thick as you can find ! you can run dual joint with gear diff but usualy outdoor I run std cvas because you cant notice much chatter and they get in the corner a little butter but may not be as smooth.
The closest to 57 is 3 ! but 3 is a little smaller even and if I was to run ae piston I would run a number 2.
Originally Posted by mcdomdom View Post
Hi Kevin!
Dominik!
Hi Dominik, I will try and get the setup on AEs webpage this week ! I ran something similar to what rick posted except I had my rear roll center in 1 B instead of 2B, I had the ackerman all the way forward instead of middle like rick, I had my camber link in the rear on the top hole not middle on tower and I ran 1,1,1.5 Piston with 50wt oil front and 37.5 rear ! I think thats about it. Let me know if you have any questions
Originally Posted by M.Abramowicz View Post
hi Kev!
Your fan,
m.
Hi Michael,
I usualy run 3A front 0B rear !!! for front arm mount ! If you go to 0B-1B it will raise the roll center making the car a little bit more responsive but should push a little bit more in the middle and out of the turn.
Hey Keven.
I am done using hair dryer since it could hurt my hair ! Actually, Paul Lemieux gave me this tip long time ago when he used to do his hair. You dont want to use regular shampoo ! it is pretty trick here, you want to use soap only and dry gently with a towel it will hold better, if it doesnt work you have to do it again. Thank you so much Paul, I owe you one
Originally Posted by DARKSIDE View Post
Keven ygpm
Back at you !
Sorry to hear that. I know there was issues at some point with the cva but I am sure if you send those back you can get new one free og charge but I know it is frustrating but I am sure you will like the car once you get to drive it.
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 06-08-2011, 08:55 PM   #250
DARKSIDE's Avatar
Default pm
your pm didnt come in?
Old 06-09-2011, 04:48 AM   #251
Originally Posted by Keven H View Post
Hi Michael,
3A/0B gives some anti-dive?
I think I must try it.
Michal Abramowicz
Old 06-09-2011, 05:44 PM   #252
Tonight I got as far as installing diffs and shock towers. Missing two more screws, and if that wasn't bad enough, I checked the tweak after installing the topdeck and tightning the screws on a flat surface, the front of the chassis has a millimeter and a half bow in the front. Looks like I will be calling associated again tomorrow. Very dissapointing build to this point.
Old 06-10-2011, 04:15 AM   #253
Big Features's Avatar
Kev, sent you a PM.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 06-10-2011, 06:27 AM   #254
Andrew Gray's Avatar
Default Re: Lemieux Hair Styling Tips
Wow Kevin, that's an old picture. That is from the Halloween Classic 2003 at The Gate when it was still upstairs in the ghetto strip mall. Ahhh, the good ol' days foam tire mod touring car when the XXX-S & TC3 ruled the roost
Retired & Washed Up. TLR Supporter For Life
Andrew Gray is offline   Reply With Quote
Old 06-10-2011, 06:54 AM   #255
FERNANDO.G's Avatar
Andrew Gray....about time for a com-back NO.!!!!
ARC USA.TITAN.BLITZ. VIPER USA.HORIZON-HOBBY.JACO. AIRTRONICS. TEAM TRINITY.
TEAM DYNAMITE.
FERNANDO.G is offline   Reply With Quote
