Old 04-20-2011, 08:40 PM   #211
chubbspeterson's Avatar
Kevin!
I miss you.....
Mike Demone
7-Eleven, National Accounts Manager
Ridgemont, CA, 90026
"I vowed to never let this happen.."
chubbspeterson is offline   Reply With Quote
Old 04-27-2011, 08:04 AM   #212
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
you best bet right now would be the SXX stock spec V2 ! in modified you can run it on on 0-0 ore 1-1 on the feel and boost ! not any higher.
LRP site says Stock Spec has turn limit of 4.0. For LRP, how well does the ESC handle, lets say a 4.5-5.5?
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
Dane is offline   Reply With Quote
Old 04-27-2011, 10:55 AM   #213
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
hey Kev,
whats a good starting point setup for the tc6 on asphalt? I race on medium to low grip surfaces asphalt mostly, but sometimes at Norcal Hobbies which is medium to high grip asphalt.
Ive seen guys talking about your carpet setups a lot, but never about asphalt setups.
Nick George
www.localrcracing.com
bagged69chevy is offline   Reply With Quote
Old 04-27-2011, 08:09 PM   #214
Originally Posted by Edgar_P View Post
And TC6, any updates before long? TC6.1?
Originally Posted by Logi Maker View Post
It's in the works...
Originally Posted by Keven H View Post
Hi,
We have been running this configuration since snowbird back at the end of january ! It seems to work very good but this is just rough prototype. At this point it is too early to say any release date or anything but something we are working on.
I like 14 gauge the best ! With 16 gauge, it seems to heat even more and give me less run time in mod. Hope this helps.
Hi, we used to do it more on the tc5 ! the the more screw you take out in the rear the more rear traction you will have to a certain extend and vice versa. On the tc6, the only screw we play with is the one on the top deck where the spur gear mount is.
I have been running the LRP x12 17.5 in all my cars when running stock classes with great success. Very good balace of torq and top end and is very durable as well.
I thought we went through this before ! but here is the latest I have... Stealth lube twice a day, in the morning and before you go to bed ! Apply gently on your face and let dry.
Hmm, should I wait a bit to get the TC6 if the 6.1 is in the works?
skinart76 is offline   Reply With Quote
Old 04-30-2011, 09:35 PM   #215
Trader Rating: 77 (100%+)
Default Thanks
Kevin, thanks for all the help with the car today at the track.
Second congrats on owning the TQ so far for the weekend. Your car was dialed. Good luck tomorrow.
Lastly, if any of you ever get a chance to ask Kevin questions about your car, do it. He is the most approachable pro I have met, I am sure there are plenty, but he was really helpful.
goin2drt is offline   Reply With Quote
Old 05-04-2011, 10:39 AM   #216
As long as you run the esc on 1 on the timing profile it will be ok ! it will hold up but a fan might be necessary.
Originally Posted by bagged69chevy View Post
hey Kev,
Hi, we have came up with a new asphalt setup that seems to work very good this last week end ! I will have the setup posted on teamassociated,s website as soon as possible ! this will be what I will start at the Reedy Race at the end of the month.
this post was talking about the 12 scale car but it is still a little ways away.
Thank you ! my pleasure to help you glad I was able to, if you need any help feel free to message me.
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 05-04-2011, 11:14 AM   #217
Get it fast, it's an order, LOL.
jorgesimes is offline   Reply With Quote
Old 05-07-2011, 05:54 PM   #218
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hi keven! when using the spec-r gear diff are you guys using different cv shafts and axles or modifying the stock tc6 ones. i remember seeing somewhere that juho was using the 3 racing sakura zero cv shafts thanx
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 05-07-2011, 10:19 PM   #219
Hi, I use the stock CVA with spec R diff. You need to either take a little bid of material off the oudrive to make it fit freely or you can dremel the ball on the drive shaft to make it fit.
Juho ran the ti racing cva for a little while but I am not sure what he uses now.
My latest asphalt setup has been posted on www.rc10.com for those interested ! If you have any question feel free to ask
Keven Hebert
Old 05-08-2011, 12:54 PM   #220
thanx!!
Old 05-08-2011, 01:44 PM   #221
That's cool!
Just a couple of questions about your latest tc6's setup: why were you running so wide in the front? (3.5mm shims) What's the difference in using a stiffer spring in the inner hole of the arm instead of a softer spring in the outer hole?
Thanks!
Fastfreddy74 is offline   Reply With Quote
Old 05-08-2011, 02:20 PM   #222
Default Droop
Kevin,
When you measure the droop on your WCRC set up at what points do you measure. Meaning from where to where is the 7mm.
Thanks.
Old 05-09-2011, 05:11 AM   #223
Kevin,
Thanks.
Hi!
Read this:
http://www.teamassociated.com/pdf/ca...droopgauge.PDF
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 05-10-2011, 05:55 AM   #224
Geberit's Avatar
Hi K.
I see you nad Juho have a carbon bumper at the back some shock tower!?
From which car is it?
Regards
Geberit is offline   Reply With Quote
Old 05-10-2011, 02:01 PM   #225
Originally Posted by Geberit View Post
Hi K.
Regards
It is rear tc6 tower, little cut to fit.
m.
Michal Abramowicz
