Old 04-10-2011, 12:00 AM   #196
RacinJ's Avatar
Keven, What is the status of a new Associated 1/12 scale car?
We've been seeing prototypes tested at big races worldwide.
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 04-10-2011, 02:45 AM   #197
Edgar_P's Avatar
And TC6, any updates before long? TC6.1?
BMI COPPERHEAD 12
Edgar_P is offline   Reply With Quote
Old 04-10-2011, 01:19 PM   #198
Logi Maker's Avatar
Trader Rating: 49 (100%+)
It's in the works...
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 04-11-2011, 08:55 AM   #199
tommy911t's Avatar
Trader Rating: 50 (100%+)
Default New Whip?
I've never seen this battery placement.
Is this in production?
http://robspics.com/index.php?option...emid=3#joomimg
tommy911t is offline   Reply With Quote
Old 04-11-2011, 09:20 AM   #200
read this: http://www.cmldistribution.co.uk/new...iew=0000001690
jorgesimes is offline   Reply With Quote
Old 04-13-2011, 08:31 AM   #201
Default Wire Gauge on 12th Scale car
Keven,
What wire gauge do you run on your 1/12th scale modified class car?
Thanks,
kevikevtmc
kevikevtmc is offline   Reply With Quote
Old 04-13-2011, 11:40 AM   #202
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
Hey Kev,
I noticed some guys remove certain screws from the top deck and bottom of the chassis to create more flex. Which screws are ok to remove?
Also, what are the effect of removing screws on the top deck as opposed to the chassis. Also front screws opposed to rear screws?
Nick George
www.localrcracing.com
bagged69chevy is offline   Reply With Quote
Old 04-13-2011, 02:11 PM   #203
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Keven,
For running 17.5 boost, 17.5 no boost, and mod, which LRP ESC would you suggest? Stock Spec v2 or TC v2?
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 04-13-2011, 06:02 PM   #204
hi kev
recomend me the best 17.5 motor
thanks
junior48 is offline   Reply With Quote
Old 04-13-2011, 07:18 PM   #205
Canyon's Avatar
Trader Rating: 8 (91%+)
Keven,
How do you keep your girlish figure?
Canyon is offline   Reply With Quote
Old 04-14-2011, 03:01 PM   #206
Hi,
We have been running this configuration since snowbird back at the end of january ! It seems to work very good but this is just rough prototype. At this point it is too early to say any release date or anything but something we are working on.
Originally Posted by kevikevtmc View Post
Keven,
Thanks,
kevikevtmc
I like 14 gauge the best ! With 16 gauge, it seems to heat even more and give me less run time in mod. Hope this helps.
Originally Posted by bagged69chevy View Post
Hey Kev,
Hi, we used to do it more on the tc5 ! the the more screw you take out in the rear the more rear traction you will have to a certain extend and vice versa. On the tc6, the only screw we play with is the one on the top deck where the spur gear mount is.
Originally Posted by Dane View Post
Keven,
you best bet right now would be the SXX stock spec V2 ! in modified you can run it on on 0-0 ore 1-1 on the feel and boost ! not any higher.
Originally Posted by junior48 View Post
hi kev
thanks
I have been running the LRP x12 17.5 in all my cars when running stock classes with great success. Very good balace of torq and top end and is very durable as well.
Originally Posted by Canyon View Post
Keven,
I thought we went through this before ! but here is the latest I have... Stealth lube twice a day, in the morning and before you go to bed ! Apply gently on your face and let dry.
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 04-15-2011, 07:03 PM   #207
Hey Keven,
Thanks for your reply! What do you do if anything to make sure your 1/12th scale car comes in at weight? Do you run ballast? How is the stock left to right bias of the 12R5? Also what is the front to rear distri ution of the new associated prototype versus the regular 12R5? I am interested as I am considering gettine one seeing how you handily beat the field back in august.
Cheers,
kevikevtmc
Old 04-18-2011, 05:21 PM   #208
Hey Keven,
Cheers,
kevikevtmc
Hi, Usualy my 1/12 is at weight without any led weight or 7 to 14 grams. It seems like left to right is very good out od the box depending on what electronics you run but it should be close. As for front to rear i am really not sure I know on the new car it has more weight on the front but can,t say any measurement for sure. Hope this helps
Keven Hebert
Old 04-20-2011, 02:31 PM   #209
Canyon's Avatar
Ahhhhh, I see. Wait, the red label or black label?
Old 04-20-2011, 02:37 PM   #210
infokiz's Avatar
Black label, red is silicone lube.
infokiz is offline   Reply With Quote
