Old 03-01-2011, 10:32 AM   #166
kevin cole's Avatar
Keven & Joe dominate The Circle City On Road Champs at R/CAR Indy
The Team Associated boys clean up with loads of hardware from...
The Mid-West Grand Slam Series Finale at R/CAR Indy
~R/CAR Indy~ http://rcarassociationindy.homestead.com/
~Team Upgrade RC~ http://www.rcidcustom.com/upgraderc/index.html
~Rock Star Paints~ www.rockstarpaint.com
kevin cole is offline   Reply With Quote
Old 03-01-2011, 02:30 PM   #167
Originally Posted by M.Abramowicz View Post
Hi sweety!
Where is this 63.7mm?
L or R side?
Attachment 712441
edit: probably R side
So what lenght is almost perfect?
Yes ride side it is !!!
Originally Posted by jag88 View Post
Hey Keven, just wanted to say 'thanks' for all the help yesterday. Everything you suggested was spot on.
Barry
MSI
Hi Barry,
No problem it was good seeing you again. It is nice to see more people running the tc6 in the area ! glad you like the car and if there is anything I can help with send me a message on here.
Originally Posted by Juiceman View Post
Hi all, first time post.
Just got back into it after a 10 year sabbatical , if you can call ten years that!
TC 6 , Modified with rubber tires.
Problem. not enough steering in general. Guess it's a good place to be, now looking for steering instead of rear end.
I have turned up the Dual Rate and lowered the steering exponential to get a 'feel' of handling but want to find it mechanically so it is kinder on front tyres. Car feels a bit too safe with this much 'push'. Also sledges a little bit under braking so can never get into a corner late as have braking set reasonably low to focus on corner speed.
Looking for fine tuning options.
Solutions i am thinking :
1/less rear toe (from 3.5 to 3) ?
2/Shorten front and rear camber links to : Front 5 / Rear 4A ?
3/Shorten front wheel base ( from 2 to 1 ) ?
Track is open fast flow with some technical sections : nhrccc . org . nz
Awesome thread BTW. Any comments appreciated.
Very true Steve, wasn't too sure on how 'overkill ' i should be with setup info
bodyshell : Titan - Mazdaspeed 6
Tekin redline 6.5T/ tekin rs pro - using boost to increase mid range punch and turbo top-end for massive straight. Went 6.5T to be able to put power down smoothly as track is low/mid grip. outdoor asphalt.
silver springs all corners / 50 wt oil /piston 2/ black sway bar front and back
0 B mounts all round. longish wheelbase for sweepers and general track. Widened track by front 1 and 1. rear is 1 and 3.5 + 1 degree toe block. giving overall 3.5 toe in rear. Droop TC measurement 5 front , 4 back. camber 1.75 all round
played with set up for a while and the above ( except toe in ) is pretty much where I have ended up with a stable/consistent/ lots of traction/easy to drive car so think I want to concentrate on small fine tuning changes.
Am consistent enough ( .3 secs ) to be able to feel the difference in fine tuning.
Was thinking about trying out ISF bodyshell as apparently it has more front downforce.....
Really should try to minimize rear toe first i think.
Lord , please give me more entry and exit steering.
Thanks to all replies, much appreciated.
Off to track to test!
Jimmy.
NZ
the one thing I would do is definitely use less reat to ! Usualy on asphlat I run 2mm so it is close to 2.3 degree. Also, you can raise your front shock up 1 or 2 holes that would be good for entry steering. The other thing is I would try to play with Ackerman. I would go with the 7block and have it all the way forward and outside on the steering block.
Hope this helps , if you have anymore questions, please feel free to ask.
Originally Posted by syndr0me View Post
It was good hanging out with you and the associated boys this weekend.
I'm about to make the switch to KO, and was wondering what servos you use in TC and 1/12?
Hi ,
was nice seeing you as well ! good to hear about KO. I have been running the new RSX servos (speed) for Touring and I have been running the 951-ICS for 1/12 ! I have ran my 1/12 servo for about 2 years now with no issues.
Thanks for the picture Kevin, it was nice meeting you at the last grand slam race. Very nice facility and very nice people ! had a good time.
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 03-01-2011, 06:48 PM   #168
syndr0me's Avatar
Trader Rating: 32 (100%+)
Thanks Keven. One last question. With the SXX-SSv2 and the 4.4 software, any suggestions on where to start with an X12 17.5? I heard you guys were trying the 3 dot insert? This is in TC.
syndr0me is offline   Reply With Quote
Old 03-01-2011, 07:23 PM   #169
jag88's Avatar
It looks like we will be switching to 17.5 boosted (maybe next week). It would be great to run with you and Joe. Stop by and show us the fast way 'round .... lol.
jag88 is offline   Reply With Quote
Old 03-01-2011, 07:35 PM   #170
I had been running the v.4.0 at the last few races I have gone. Seans car at snowbird had the 4.3 in it this is the latest I have tried and to me the 3 dot timing was better. if I was to run 17.5 again I would start with the 4.3, setting would be 3-5-7-2 and then a 6.4 gear ratio is where I would start ! Hope this helps
Hi Barry,
Unfortunately I am back home in quebec now but I would love to make it back there sometime soon !
Keven Hebert
Old 03-01-2011, 08:03 PM   #171
hi keven i have a lrp esc version2 and my fan keps getting lose how can i fix this
f1o7x9 is offline   Reply With Quote
Old 03-01-2011, 08:24 PM   #172
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Try a small dab of shoe goo on the screws...
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
Old 03-01-2011, 08:24 PM   #173
Logi Maker's Avatar
Carpet NATS!!!!!!
Kyle Predmore
B6D|B64D
Old 03-01-2011, 09:33 PM   #174
mmmm good idea thank you
Old 03-02-2011, 03:07 AM   #175
or try to squeeze a little the spaces in the heatsink with a plier.
jorgesimes is offline   Reply With Quote
Old 03-02-2011, 08:45 PM   #176
pyro854's Avatar
I was thinking about turning my TC5 into a Mod car since i cant afford another new TC6. I was going to put in a SXX TC Spec v.2 and Vector X-12 combo, i was wondering on which motor i should put in and if you had a good starting setup i could put on the car.
pyro854 is offline   Reply With Quote
Old 03-03-2011, 06:58 PM   #177
Donny Lia's Avatar
Keven once told me,
"I AM the RC industry"
He is my inspiration to compete at the top level!!
He is my "Tommy Vu Tong"
Thank you Keven!!!
RocheAwesomatixTrinityKoBsrProtoformTQAvidKimbrough
Donny Lia is offline   Reply With Quote
Old 03-03-2011, 10:17 PM   #178
kevin cole's Avatar
hey kev...text me your email address again.
I deleted it by mistake.
Old 03-04-2011, 02:07 AM   #179
cheers, Keven. reducing rear toe 1mm each side( spacer) ;prolly need to drop my steering D/R to keep it in check but think it might just let me get on that edge for a faster lap instead of pushing around the track.
As for the suggestion of 'uprighting the front shock top' I will definitely try that sort of adjustment . Currently 3B front 2A rear ( cheating on rear to find more downward travel from shock rather than lengthening shaft ) . maybe thats counter productive?! or I could lessen downtravel all round by 1 and hopefully that keeps balance, just hard to say with soft setup as the car rolls a bit....
Who knows
Cheers for your advice.
Juiceman is offline   Reply With Quote
Old 03-14-2011, 01:27 PM   #180
Hey keven what cva are you using on the front. And do you have a part # thank you good luck on you upcoming races
