Old 02-15-2011, 08:25 PM   #151
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by Keven H View Post
I have always ran my steering block like I did on my tc5 regardless of the arm mount or castor block I have been running ! I dont think you can gain or loose from it is more of a feel thing. When you ran them like I do you can add shims to it to make the car easier to drive or you can run it low as well !
Hope this helps.
Haha thanks it was nice to meet you to ! Hopefully I can make plans to go to the last one in germany !
Yes I have been running silver spring since december on my car. I feel like it gives me more on power steering and makes the car a little more stable as the green spring made the rear end a little too soft and rolled over the rear just a little too much ! I still run 0B roll center in the rear.
Otherwise there is no major changes in the setup I have been running. I plan to do some testing in the next 2 weeks with 2 races in the next 2 week ends so if I come up with anything better I will post on here.
thanx for all the help keven
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 02-20-2011, 09:10 PM   #152
Send a message via AIM to Jonesy112
Thanks for the help this weekend at the Grand Slam race Keven. Hope to see you back at the big rug for some more races before too long.
Michael Jones
RC America - X-Ray - Team EA Motorsports - RockStar Paint - Apex RC Proshop - ProOne Tires
Jonesy112 is offline   Reply With Quote
Old 02-21-2011, 10:18 PM   #153
Blue Screw's Avatar
Send a message via AIM to Blue Screw
hey kev. question for ya.. steering rod ends for bump steer normally how do u run ur links..level? what wouldhappen if the were agnle down a little and vise versa if they were angled up
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 02-22-2011, 08:10 AM   #154
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Keven, can we see a setup sheet from ets?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 02-22-2011, 01:57 PM   #155
turbodog's Avatar
Also, what shock length?
Troy Schafer
turbodog is offline   Reply With Quote
Old 02-22-2011, 03:44 PM   #156
hey kev would the yokomo BD5 Gear Diff fitt the tc6. and if it dose what do i have to do to make it fit
f1o7x9 is offline   Reply With Quote
Old 02-22-2011, 04:07 PM   #157
Not a problem ! had a great time hopefully I can make it back there !
I pretty much always run level, or angled up a little ! I never run them angled down ! the more angle up you do the easier the car is to drive !
I will try and get something to associated to post in the coming week ! It is actually very close to my latest carpet setup just a few changes being a little bit narrower front end and thinner front oil !
I have to mesure them again! I beleive it is 63.7mm
Yes the yokomo diff will fit with some dremel work ! you might have to make the car 1mm total wider in the rear for the bone to clear the outdrive so it doesnt bottom out.
Hope this helps
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 02-23-2011, 03:09 AM   #158
Hi sweety!
Where is this 63.7mm?
L or R side?
Ask Keven Hebert, TeamAssociated / Reedy / ApexRC-amor.jpeg
edit: probably R side
So what lenght is almost perfect?
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 02-24-2011, 08:59 AM   #159
jag88's Avatar
Hey Keven, just wanted to say 'thanks' for all the help yesterday. Everything you suggested was spot on.
Barry
MSI
jag88 is offline   Reply With Quote
Old 02-27-2011, 07:03 PM   #160
Thumbs up
Hi all, first time post.
Just got back into it after a 10 year sabbatical , if you can call ten years that!
TC 6 , Modified with rubber tires.
Problem. not enough steering in general. Guess it's a good place to be, now looking for steering instead of rear end.
I have turned up the Dual Rate and lowered the steering exponential to get a 'feel' of handling but want to find it mechanically so it is kinder on front tyres. Car feels a bit too safe with this much 'push'. Also sledges a little bit under braking so can never get into a corner late as have braking set reasonably low to focus on corner speed.
Looking for fine tuning options.
Solutions i am thinking :
1/less rear toe (from 3.5 to 3) ?
2/Shorten front and rear camber links to : Front 5 / Rear 4A ?
3/Shorten front wheel base ( from 2 to 1 ) ?
Track is open fast flow with some technical sections : nhrccc . org . nz
Awesome thread BTW. Any comments appreciated.
Juiceman is offline   Reply With Quote
Old 02-28-2011, 08:28 AM   #161
wtcc's Avatar
Did you try to change the droop setting? Try 6mm front and rear. If it still has understeer try 7mm in the back. This should work!
wtcc is offline   Reply With Quote
Old 02-28-2011, 09:04 AM   #162
less toe is the way to go 3,5 is very much
2-2.5 is ok depending on surface and conditions
1.5 - 2 for lower motor power.
greetings
thilo-alexander is offline   Reply With Quote
Old 02-28-2011, 10:58 AM   #163
corallyman's Avatar
Trader Rating: 97 (100%+)
What body are you running on your TC? They can make a huge difference in performance.
You should list more of your setup and car choices, like motor wind, etc.. It will only make Kevin's suggestions easier on him to help.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 02-28-2011, 04:38 PM   #164
Wink
Very true Steve, wasn't too sure on how 'overkill ' i should be with setup info
bodyshell : Titan - Mazdaspeed 6
Tekin redline 6.5T/ tekin rs pro - using boost to increase mid range punch and turbo top-end for massive straight. Went 6.5T to be able to put power down smoothly as track is low/mid grip. outdoor asphalt.
silver springs all corners / 50 wt oil /piston 2/ black sway bar front and back
0 B mounts all round. longish wheelbase for sweepers and general track. Widened track by front 1 and 1. rear is 1 and 3.5 + 1 degree toe block. giving overall 3.5 toe in rear. Droop TC measurement 5 front , 4 back. camber 1.75 all round
played with set up for a while and the above ( except toe in ) is pretty much where I have ended up with a stable/consistent/ lots of traction/easy to drive car so think I want to concentrate on small fine tuning changes.
Am consistent enough ( .3 secs ) to be able to feel the difference in fine tuning.
Was thinking about trying out ISF bodyshell as apparently it has more front downforce.....
Really should try to minimize rear toe first i think.
Lord , please give me more entry and exit steering.
Thanks to all replies, much appreciated.
Off to track to test!
Jimmy.
NZ
Old 02-28-2011, 10:52 PM   #165
syndr0me's Avatar
Trader Rating: 32 (100%+)
It was good hanging out with you and the associated boys this weekend.
I'm about to make the switch to KO, and was wondering what servos you use in TC and 1/12?
syndr0me is offline   Reply With Quote
