Team Corally RDX Touring Car
#946
Thanks!
So I'll need to get another black delrin piece for the front ball diff right?
and thanks for the dust prevention tip never thought of that.
This forum is awesome!
#947
Yes, that would be ideal.
You're welcome, always a pleasure to help!
//Martin
//Martin
#948
Hey Guys........ quick posting about the weekend.
Chris Tosolini WINS 12th GTP Modified
Jeff Cuffs TQ's and WINS Stock Touring
Jeff Cuffs WINS 19T Sportsman Touring
5 RDX cars in the 19T Sportsman A-main with 4 of Top 5 finishing positions.
Corally Cars all over the A-mains. Tosolini used the SP12M Ahoniemi Edition Car.
Setups should be up by the end of the week along with more racing information.
#949
Corally USA.
Are you doing exchanges on the alu portion of the ball diff. for the delrin one? I purchased a kit with a separate ball diff, should I just use the alu one?
also i saw a white dif gear on Simo's car on the Corally International site. Is that available? Thanks!
#950
I guess you're gonna run a hard front diff anyway, so use the alupulley there, and also do the protective tape trick. There's no big problem using the Alu. but it's very open, so carpet gets in there a bit too easily...
The white piece is also delrin, as the black one(At least my black one is). I got two of them before christmas, they're great!
#951
TEam Corally,
Whats up with this car that on carpet you guys are running less caster it seems than other cars? I have heard of Chris running 2 deg?
This is a knowledge thing. Running the car for only about 5 days now-I already know to throw the set-up book out the window. This amazing car walks to the beat of a different drummer.
Shed some light!! Help us shadetree tuners out.
Ray
Ray
#952
In Europe with the RDX on rubber/moldeds we run 2deg casterblocks with a one-way diff upfront!
Indeed it's amazing this car still is in control, and really fast to top it of.
If anyone told me 2deg+oneway would be fast, I'ld say they were crazy, but......
#953
Ray...
It depends on the track. I believe all of us ran 4 deg this weekend. You only see 2 deg in the high speeds of Modified to get more turn in. It takes away mid to exit turning though. Typically stick with 4 deg to take away turn in sensitivity and hold the lines better coming out of the corners.
Jeff
Jeff
#954
Thanks guys-I have been running 6 deg with antidive in the low roll position. I feel like it maybe has just a tick too much front end bite for long fast corners-so I was going to try 4 deg caster with antidive Thursday. See if it gets faster in those corners. I could use a bit more turn in vs. mid-off steering too-so this might be the ticket.
Ray
Ray
#955
Usually, with rubber tires and oneways anyway, I've used less caster on carpet tracks with all my cars(TC3 2 dgr, Xray 3 dgr, on the Pro4 I used as much as 4 to calm it down), mainly because they're smaller and with shorter corners. On outdoor tracks, it's usually more sweeping corners, and thery're usually bigger. My opinion has always been that although more caster can feel a bit more understeered, it pulls off more speed through corners, whereas less caster feels more agressive into the corners, but since the tires have so much less angle, they have too much of a braking effect.
Indoors on rubber, you often need that braking effect into turns, and you also need the steering effect into hairpins and the likes.
Hope someone got smarter, or.. well... Whatever
This may be very different for foam tires also....
#956
Big thanks to Rob Michaels and the rest of the guys at Corally USA and Superior Hobbies for the support and parts this week at the Snowbirds.
#959
O.K. her is my question.
I'm running Cuffs setup from the website with Cyan and Magenta tires. After a day of running my fron tires are smaller than my rear tires. The car is not pushing or loose, it is very neutral, but every car I ever ran has worn the rears (softer) twice as fast as the fronts. I'm wondering if it's because of the weight bias or maybe I have something weird going on.
