Team Corally RDX Touring Car
#8581
Originally Posted by syndr0me
Ah, it was Still Bill, not Sushi Boy. I got the initials right at least. Sorry!
And I still have that setup going on my outdoor car. Gonna have to finally break open one of the packages of 80% rear arms to check them for any toe-in.
Hmmmm...Might just save the rest of my 80% f/r arms for my carpet car setup at Las Vegas. Kinda wonder what Jeff Brown thinks of that notion? His setups are awesome.
Still Bill (after having been XXX-S and JRX-S Bill)
#8582
Mounting of Sway Bars on new 35% arms
Jeff,
Can you show how we are supposed to attach sway bars to the new arms?
Does it require additional hardware?
Many thanks.
Bill
Many thanks.
Bill
#8583
On the new 35% arms, are the rear hubs supposed to be really tight in the arm? It makes the hub not move freely. Thanks
#8584
Jeff Brown has posted a a page or back talking about how they will fit tight and to file them a bit. They didn't want to wait any longer because everyone has been waiting on the new arms forever. Future batches will be fixed and will be a direct bolt on without any trimming.
-Korey
-Korey
#8585
Originally Posted by CorallyUSA
NOW AVAILABLE! The new suspension arms for the RDX are released in the 35% hardness. The arms feature all new design and have been beefed up.
RDX CF6 Wishbone Front 35 (1 pc.) PART NO. 79060
RDX CF6 Wishbone Front 35 (4 pc.) PART NO. 790604
RDX CF6 Wishbone Rear 35 (1 pc.) PART NO. 79070
RDX CF6 Wishbone Rear 35 (4 pc.) PART NO. 790704
PLEASE NOTE:
The rear hubs are a snug fit on the arms and will require a little work to free them up. We simply did not want to delay them any longer and will continue to improve them in future batches.
PLEASE NOTE:
#8586
Originally Posted by Still Bill
Jeff,
Many thanks.
Bill
Many thanks.
Bill
Jeff
#8587
Thanks Jeff and Korey.
#8588
Do you think the new 35 arms would take away steering compared to the old 75% arms (in the front)? I switched them last night, and it felt like maybe it had a little less steering. It was incredibly drivable though, and went right where I put it. Brian's setup from the Novak race is really smooth.
#8589
New RDX owner here again.
Could someone explain what numbers on each arm mean? I have 4x 75 arms that came in the kit, what are the 35?80? ect ect. Could some one list all available and what the difference is?? Thanks
Sway bar installation in the rear? The manual forgets to give instructions.. any pics of the sway bar installed for me to look at?
PS got the car built not to bad, i normally run xray so im a little critical about looks and quality, but this rdx is quite nice the shocks im so glade came built and bleeding them was simple, i got 4 shocks built the same in one try.. The manual is kinda ho hum...
Thanks again for the help
PS: Still looking for a baseline setupsheet for Stock motor,DUAL DIFFS,rubber tires on ozite carpet. 80x40 track
#8590
my 1 answer!
#8591
Thanks i also should have elaborated..
So lower number =softer compound. And from what i hear 75% breaks easier so i may look for some lower numbers..
I guess the other question would be what is the difference between front and rear. As i understood it my 75s are all the same.. Now there are front and rears. Is it possible to get just rears and use them up front to lower amount of parts i need? I beleive the rear would just have more mount possitions that i could just ignor for the front of the car?
#8592
The 25%, 50%, and the 75% are the "old" style arms. The 35% and 80% are the "new" style arms. The "new" arms don't need the rear shock extension and the have more holes for tuning. The 80% arms arent being made any more from what I understand.
#8593
Ok thanks just want to get it straight so when i get spares im not buying stuff i dont need..
-Number= hardness
-New versions add more holes
-New versions are direct replacements and dont change any of the toe settings?
-If your a cheap bastard like me i could just buy rears and use them up front and ingnor the extra shock mounting holes?
Thanks sorry to beat this question to death.
-Number= hardness
#8594
the last one is false, joel. look closely at the picture posted of the arm comparison. the cut is not long enough to allow the castor block to fit in the new rear arms. you will need dedicated front and rear arms. or just use all fronts and ignore the new rear hub offset tuning option.
#8595
Joel let me know how you like the car ?
