Old 08-05-2006, 09:38 AM   #8386
Drcy's Avatar
Default Wheel Hex
Originally Posted by T1Raycer
i have question
do you know any other hex wheel that fit on the rdx other than the corally ones??? one from the T2 and tamiya seem to look that they re gonan fit but i want to make sure wich one fit on the car??
Later!!
I also asqued that before without answer....
I would like to know how work the Xray ones and the Schumacher, does anybody knows???
cheers
Drcy is offline   Reply With Quote
Old 08-05-2006, 04:29 PM   #8387
I asked about solid, non-clamping hexes awhile ago, and never got much response. The people that did respond didn't understand why anyone wouldn't want clamping hubs. I machined down some super wide ones I got when I was running an antique Yok sedan. But I need some 4mm axle shims. Really, there is no reason Corally couldn't release these hubs in a non-clamping version. Heck, it'd be CHEAPER to make them that way. Leave out the machining and drilling/tapping steps, and drop the cost of the bolt. Less time and fewer manufacturing steps means Corally makes more money on them. Or Speciallized RC could make them. HINT HINT Jeff!
Stealth_RT is offline   Reply With Quote
Old 08-05-2006, 07:17 PM   #8388
Trader Rating: 38 (100%+)
I think the issue with the non-clamping version is if you arent careful you can lose the pin in the axle.
or8ital is offline   Reply With Quote
Old 08-05-2006, 07:34 PM   #8389
HarshGuy's Avatar
Originally Posted by syndr0me
I was talking about both. The hexes are fragile, especially the narrow hexes.
I was also wondering about the new narrow rear hubs, and why people are using them. I believe if you use them, you can run the wide hexes in the rear which are more durable.
I used the HPI ones in order to make ROAR width at the carpet nats, they are "inbetween" width of the Corally narrow and wide hexes and worked perfectly.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 08-05-2006, 10:01 PM   #8390
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Does HPI only make one hex, or could you provide a link or part #? Thanks crazy monkey avatar man.
Old 08-05-2006, 10:09 PM   #8391
Still Bill's Avatar
He's really a NICE guy...Just a bit crazy...
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 08-06-2006, 05:17 AM   #8392
HarshGuy's Avatar
I'm not sure!! A local racer told me about them, then I went to my LHS and picked them up there, if I remember correctly they were "relatively" spendy becuase they included a bunch of shims to be able to widen the wheels more. You can call my LHS Speedworld Raceway 916-771-5318 or email is [email protected]
Old 08-06-2006, 08:08 AM   #8393
Still Bill's Avatar
I don't know the actual part number either; but, when I saw them at a couple different LHSs they ranged from $32-35.
Old 08-06-2006, 08:35 PM   #8394
Default gearing
need help with gearing,any sugestions with a starting point where to start with spur gear size,i have a 100tooth spur right now came with the car i bought off someone.i am running on asphalt with a 150ft straight away running a monster stock motor with 4 to 5 ft wide lanes and do you have to use corally spur gears with the corally?sugestions on brand.
imber is offline   Reply With Quote
Old 08-06-2006, 11:38 PM   #8395
An answer and a question.
Dunno about the gearing on asphalt (on carpet with a 90ft straight we run a 6.36 or so with monsters which would be a 100/31 or so) but you don't have to use corally gears. I happen to like Kimbrough simply because theyre everywhere and cheap.
Harsh, Jeff, shushi Brian and company . . . what diameter turning radius you end up with when running foam on carpet? With what ever radius you use to race is there "room" to turn up your epa's or DR to get the wheels to turn further or are you running at max? just curious
Old 08-07-2006, 06:21 AM   #8396
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
I usually set it fairly close to max (furthest travel before the rims hit the shocks on the track, bench is different), but leave a little room incase I need a few extra clicks of it sometimes. I just tune the car to my liking from there.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 08-07-2006, 11:06 AM   #8397
Big Rigg's Avatar
With a monster stock and a 100t spur I'd start with a 28t pinion that'll give you a 7.14 ratio... that sounds like a big track though so you may need go up just a hair... try it and go from there... good luck
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 08-07-2006, 11:30 AM   #8398
Slotmachine's Avatar
Send a message via MSN to Slotmachine
can anyone tell me if the T2 blades will fit the rdx?
Thanks Paul............
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 08-07-2006, 11:43 AM   #8399
Trader Rating: 22 (100%+)
I believe the corallys are smaller than xrays.
eXpress Motorsports***VBC
fastasu2 is offline   Reply With Quote
Old 08-07-2006, 03:16 PM   #8400
hi, where can i get the metal mip cvd blades from cos ive got a spool in my car and i run stock and super stock and i just keep breakin the plastic ones
jordan
jordys jrxs is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 08:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 06:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 07:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 04:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 07:40 PM
