Team Corally RDX Touring Car
#8176
Originally Posted by or8ital
Do you have this? Can you run both those fans and the one on the side? Also does it sit high enough? It looks like it is slightly above the upper deck but my checkpoint seems higher then that.
Greetings Ollie
#8177
Originally Posted by OllieRDX
Just use the Team Corally Fan Set! Thats cools the collector and thats where the motor heats up!
Greetings Ollie
Greetings Ollie
I think Ollie could be on speed! Ever notice how excited he is in every post!
No offense meant Ollie! Just pokin' fun!
Greetings Andrew
Seriously now . . .
I bought my RDX used and when I was rebuilding the diff I noticed I had 6 cone washers installed on the diff screw rather than the four the manual calls for. Is there any reason I should know about to rebuild it with six rather than four!
#8178
New Chassis for the RDX
At the worlds there was a new chassis on sight .
There are rumours that it should be released soon with a new car (with bulkheads that allow the diff easy removal )
http://www.info-rc.net/phpBB2/viewtopic.php?p=3056#3056
scroll till you find it.
cheers
cheers
#8179
#8180
Sorex Tires versus TakeOff
Hi all,
I am having one important race in a big track with medium to low grip .
Air Temperature will be 21°C or 81°F.
Since any rubber tire/insert/rim combination is allowed and no limit for the number of tires used - is a total new situation for me , used to run TakeOff C27 limited to 2 sets per race (mandatory tire).
I will be thankfull for any advice base on experience about how to get the best of this conditions, like which tire/insert can be the best
and
If is wise to use one tire set for each run (4 qualifying and 3 finals).
thanks in advance
Pedro
and
thanks in advance
Pedro
#8181
Diff washers
Greetings Andrew
Seriously now . . .
Greetings Andrew
Seriously now . . .
Hi,
I know this issue very well....
If the diff screw (the long one) is threaded all the way YOU SHOULD USE 6 new washers.
If the diff screw is one of the new generation and has close to the head a no threaded part, then you can use the 4 or 5 washers like I do.
Be aware, the washers get flat with time and have to be changed
rgds
Pedro
#8183
Some of the translated text:
"The new RDX in assay in this test of the World-wide one for the official pilots."
"The RDX of Chris Tossolini already with the specifications of the new model."
"Paul Constant, master of the Corally, offered to all Corally pilots the new chassis of next 2 RDX composition to 2 parts for the base."
"The chassis with 2mm of thickness can thus be rigidificado with triangulo now placed of 2,4mm in the front, becoming it reactivo."
#8185
Greetings Ollie
Greetings Ollie
#8186
That's funny i called Corally USA and they told me there's no new kit or new anything, and now it seems as if something new is on the make any info on anything.
#8187
does any one now the actual internal gear ratio ?
#8188
2.0
#8189
THANK YOU
#8190
