Team Corally RDX Touring Car
#7216
There will be a charity race May27th in Parkersburg,WV if any of the Corally guys are interested in running on asphalt....
jim
jim
#7217
Do people use threadlock in a lot of places on the car?
I was having these same questions last night. Very few mentions of threadlock (BLUE, NOT RED!!!) in the manual, but a lot of places that seemed like it might be needed.
Thoughts?
Thoughts?
#7218
I have been informed a limited shipment of the new arms are on the way sometime this week hopefully...have also been told they are the 80% arms and not the 35% ones...
#7219
Thoughts?
Thoughts?
#7221
New RDX
Hi,
does somebody know about one RDX new release.
Or you know how to change the roll center without taking away the bulkheads?
Or how by using XRay outdrives , change from one-way to spool without taking away the bulkheads?
Or how to keep smooth and blocked the RDX rear diff?
cheers
Pedro
cheers
Pedro
#7222
Buying a second RDX
I am considering the purchase of one second RDX.
Does somebody know which new parts are included in the last version of the RDX (new arms? new servo posts?.l..) and which chasis (2,9mm or what).
thanks in advance
Pedro
thanks in advance
Pedro
#7223
thanks in advance
Pedro
thanks in advance
Pedro
#7224
Originally Posted by CrashTstDummy
the present carpet spec kits are the same as they have been for the past several months...2.9 chassis.....no kits with the new arms or uprights yet
get to work Slacker!!!!!!!!!
#7225
jim
#7226
looks who's talking about being a slacker... ...
jim
jim
Lamo!
#7227
Okay I give up... what is the deal with the wheel hexes on this sucker? I know I'm not supposed to over-tighten the screw on the hexes, but short of CA glue, nothing in the world is going to keep them on the axles.
Am I doing something wrong?
#7229
The screw doesn't seem to tighten them enough to hold them on the axles though... they just fall off.
#7230
Sounds like you're not getting them all the way on. Easiest way to make sure is don't tighten the screw up all the way (just enough for a wheel to fit on) then put a wheel on and screw it on so it forces the hex ALL the way on. You'll probably hear a little pop, that's the hex popping onto the little pin. Then just take the wheel off and tighen up the hex a tiny bit.
