Team Corally RDX Touring Car
#6992
Just head down to your local Sears and get a pair of their small retaining ring pliers.
Try something like Craftsman #47383. I don't have mine sitting here in front of me to have the exact part number, but that's where I got mine and they work perfectly.
#6994
Originally Posted by Riketsu
Where can I buy the new diff screw?
412 561 3068 ask for Jim, he'll hook you up!
#6995
Could be a stripped plastic diff nut also. I had the same problem, replaced the plastic nut and it hasn't loosened since. I think mine was just worn out though.
#6998
Originally Posted by Customworksking
I had the same problem and it WAS the C clip it will catch if it is bent !!
Diff would back way out, because the C clip was catching. Rebuilt, put a new clip in and haven't had a problem since!
Woody
#6999
anytime i feel a tight spot in my diffs i usually just change the c-clip. usually fixes it.
Ya the ones Jamie mentioned from rcmadness are perfect size, i think they come in a set of regular and reversed for a cheap price, only way to go.
#7000
#7002
This may prove valuable for those who do not use the standard diff rebuild kit (as the regular kit has the ring but the ceramic thrust kit does not). The xray diff c-clips are the same as the corally c-clips. They are sold seperately and come in a set of like 10 for $5.75
http://www.teamxray.com/teamxray/pro...&kategoria=563
Got to be one of the most reasonable prices xray has for a part.
#7003
Originally Posted by MUDVAYNE
What C-Clip are you guys refering to?
#7004
Wow! thats cool. I will have to go pick me up a bunch! it was getting expensive buying the rebuild kit!
#7005
