Team Corally RDX Touring Car
#5656
Hey guys, I'm going to be picking up an RDX within the next couple weeks. I'm waiting for the right deal to come around.
Do the Associated springs fit on the Corally shocks?
#5660
Pete68, you should try Rob Micheal set-up from the Novak race 05...the 2 last time i use that set up at your track my car was really fast. the only thing you could change if you have too much steering with this set-up is 24lbs in front at the place of the 22lbs...and just put 1/2inside of traction front and rear.
Pace
Pace
#5661
Originally Posted by kartermdb
you are way over geared for superior, i was geared at a 28/98 for stock at superior and my car was geared almost perfect, try running about a 22 and you should be good
dont forget the straight at superior goes uphill, so you dont gear nearly as high as you think you need to
#5662
set-up
Pace
Pace
thanks!! and r coming back racing with us shortly!!
c'ant wait to see the great pace running again !!lol
Pete68
#5664
car
Originally Posted by pete68
roll block r the stock from 00166 kit and they r at position #1 frt/rear
thanks!!
Pete68
thanks!!
Pete68
#5665
SET-UP
Originally Posted by Customworksking
Ide try flatting all camber links ang they Key thing is GLUE THE SIDE WALLS OF YOUR TIRES....the softer springs set ride heigth at 5mm all the way around.....turn your dual rate down and bring it up till the car makes it around the track add a bit more and STOP there....LMK how it works
Pete68
#5666
Lo guys,
This is from International Toyfair 2006 - Nurnberg.
I think i have great news: look on first picture right behind car on cataloge NEW WISHBONES!!!
look on second picture left behind car on cataloge NEW NARROW REAR UPRIGHTS!!!
On third pic you c that Oscar Jansen comes with a new v2 Revolution motor!!!
#5668
Thats great news,now i won't hear a shout of Wishbone! everytime i catch the piping.
BTW what was wrong with the old rear hubs?
#5669
nice new arm!! cant wait ti see them on my car and test them hehe!!
Later!!
Later!!
#5670
Did i have done good work??
