Team Corally RDX Touring Car
#3181
Originally Posted by scoyle
Jeff can I ask what difference this will make?
I had a problem at the weekend that my car was pushing on corner entry (off power I suppose) - would this change help?
I currently run 1.3mm 60wt front, 40wt rear and 5mm droop all round with the shocks in kit position. Was planning to soften the front springs (from 17lb all round) to 14lb front and 17lb rear or possibly go down on the droop.
Stephen
Stephen
Pretty much longer and flatter links give you more forward traction and less stability. Shorter and angled links give more stability less traction.
Well, you are running quite a bit of droop as well. Perhaps try 3mm in the front and 4mm in the back. I would definately drop the front oil to 50wt or even 40wt. I went to 40wt all the way around and the car was 100% better on entry, mid and exit. Also try perhaps 2 deg caster if you are not already.
Jeff
#3182
Stephen
Stephen
If you want a bit more steering entering the corner I would give the rear end maybe a touch more droop than the rear (about 2.0mm in the front and 2.5-3.0mm in the rear). This will promote more weight transfer to the front off power.
You could also make the front ride height slightly lower than the rear as well. This will also promote more weight transfer to the front off power.
Raising the front camber link to the top row like Jeff has suggested will create a bit more initial turn in as well. It will also keep the front from rolling over as hard and it will stay flatter through the corner. Hope this helps a bit.
-Korey
#3184
Originally Posted by Mission_carbon
I know what the problem is now its steering i have way to much of it it will skid after coming down the straight when slowing down? how will i make it alot smoother.
Jeff i race on an open tarmac track
Jeff
#3185
Originally Posted by Sushi Boy
Ok never mind, jeff beat me to it lol
-Korey
-Korey
Jeff
#3186
Jeff: I put more toe-in on the car just now and it made it alot more smoother and i can still go into corners hard and come out of them fast i think its just about rite.
Thanks for your help,
Will
Will
#3187
Will
Will
Jeff
#3189
Thanks Jeff (and Sushi Boy) - that all makes sense. Will give it a go the next time I am at the track...
#3190
hey sushi or jeff tell me what you will do to have more steering !!! heres my set-up !! Stock Rubber on large track and on Smooth high grip Track!!
Front Suspension
Caster - 4
Kickup - 0
Toe-out - .5
Camber - 1.5
Ride Heigth - 5
WheelBase - Stock
Droop - 2mm
Anti-roll Bar- None
Front Width- Stock
Oil Piston - 50W 1.3mm
Spring - 30 LBS
Shock Mount - 3th on the shock tower from the outside
Front Link - 2th from the outside on the bottom
Rear Suspension
Anti-Squad - 1.6
Toe-in - 1.5
Camber - 1.5
Ride Heigth - 5.5
WheelBase - Stock
Droop - 2mm
Anti-roll Bar- None
Front Width- Stock
Oil Piston - 30W 1.3mm
Spring - 26 LBS
Shock Mount - 2th on the shock tower from the outside
i think i give lot of information to help me hehe!!
Later!!
Rick
Front Suspension
Caster - 4
Kickup - 0
Toe-out - .5
Camber - 1.5
Ride Heigth - 5
WheelBase - Stock
Droop - 2mm
Anti-roll Bar- None
Front Width- Stock
Spring - 30 LBS
Rear Suspension
Anti-Squad - 1.6
Toe-in - 1.5
Camber - 1.5
Ride Heigth - 5.5
WheelBase - Stock
Droop - 2mm
Anti-roll Bar- None
Front Width- Stock
Spring - 26 LBS
Later!!
Rick
#3191
First of all, that seems like awfully heavy springs for even a smooth, high-grip track and rubber tires. Why don't you try like 24/19 or even 22/19. Move the front link to 2nd from outside on the top row of camber holes. This will give you less overall camber gain but will smooth the transition to full contact patch and won't break the front traction loose. The car will feel smoother and should have more steering...in the middle and exit of the corner especially.
#3192
uk or us version RDX
thank you so much jeff brown and others for advice regarding choice of cars. i will be running at superior hobbies and TQ when i can, i want to have fun and want the nicest car possible. i will be running stock. i have been using sxt traction compound for some time with good results. If you corally peeps' are looking for new blood, count me in! set-ups for superior are welcome, too...
#3193
As Brian said, you should try going softer. I've been running on an extremly high traction asphalt track and running 19 lbs springs in the front, and 17 lbs springs in the rear. You could also try running the narrow hex adapters if you're not already. Those made the car free up, but it felt less stable.
-Korey
-Korey
#3195
what guys think about the droop of my car??? 2mm in front and 2.5mm in the back????
Later!!!
Later!!!
