Team Corally RDX Touring Car
#3110
Originally Posted by rayhuang
#2 How does the Parma Alfa do on rubber tires on carpet? Which body did Rob run at the Novak this year?
THANKS,
Ray
I won the summer sizzler at Trackside, I believe that you were there, in the rubber tire class with the Parma Alpha and this is what I can tell you about running it with rubber tires.
The body is great in low to medium/low bite, but as soon as traction gets to medium high or high, like the third round of qualifiers at the sizzler, the car starts to push. And by the time the mains come around and there is alot of bite, is nothing that you can do, within reason, to keep the car from pushing. Then switch bodies and the push is suddenly gone. Any of the asphalt bodies on the market will be a better choice for rubber tires on carpet.
Hope that this helped
Jim
#3111
just knew today that my locah hobbby store would'nt not order some corally parts !! thats suck for me!!! the only place now i can order some piece is online!! so i want to know what kind of parts that broke easily on the RDX i know that the a-arm is not pretty solid so i already bougth a pack of 4 but what other parts that it will be good to carry??
-Diff rebuilt kit
-plastic driveshaft cap
other thing??
let me know what you think??
Thanks! Later!
-Diff rebuilt kit
other thing??
Thanks! Later!
#3112
Originally Posted by jimnew
Ray
Jim
Jim
#3113
-Diff rebuilt kit
other thing??
Thanks! Later!
-Diff rebuilt kit
other thing??
Thanks! Later!
Get blades and change them every two to three runs in 19T....if you can afford the steal blades and the CVD's that go with them than get those because they last....
Diff rebuild is good
I broke a shock tower so I would say have a spare one just in case..
After that there isn;t much needed...
Spend more money on tires....LOL
-Shookie <><
#3117
you can run the stock carpet kit in 19t and you will love it!! but on carpoet you want a stiff car so : 4.0mm Chassis,3.4mm Top Deck will be a option but like i said the carpet kit its already go sor some action!! ohhh.. a diff its a must to have in 19t humm... maybe the low roll center block!!!
Later!!
Later!!
#3119
Just ran my Carpet spec. for the fist time this past Wed. at my local track. All I can say is WOW!!! While making set-up changes to the car, it responded very well. Each change was very noticeable on track. Drivetrain was extreamly smooth and free.(very quiet car) Pretty much ran the car staight out of the box. I had some problems in the qualifiers,(just with getting the car sorted out) so I started last in the Main. Went to the front very quickly and after that never saw second behind me. I cant wait for my low roll center mounts to come in. Great car. I highly recommended it to anybody.
-Dan
Ps: Scott, just buy one, you saw how well it worked.
-Dan
