Team Corally RDX Touring Car >
Old 05-24-2005, 07:07 AM
  #2206
Brian McGreevy's Avatar
Syndr0me,
Yes those do look somewhat odd, possibly old. Rule of thumb: 1.6 mm = 2 degrees toe, 1.2 mm = 1.5 degrees, .8 mm = 1 degree, .4 mm = 1/2 degree. You can use a calipers and find out how much you have.
Brian McGreevy is offline
Old 05-24-2005, 10:15 AM
  #2207
dawgmeat's Avatar
Default set-up sheet
is there a editable or interactive set-up sheet out there?
dawgmeat is offline
Old 05-24-2005, 10:53 AM
  #2208
syndr0me's Avatar
Trader Rating: 32 (100%+)
Thanks for the info Brian. I'm just relieved to know they're all the same size, despite the visual difference.
syndr0me is offline
Old 05-25-2005, 03:19 PM
  #2209
Korey Harbke's Avatar
Yeah, thats pretty weird. Never seen the ones that look smaller before. All of mine are like the other two.
-Korey
Korey Harbke is offline
Old 05-25-2005, 05:45 PM
  #2210
Trader Rating: 14 (100%+)
how big is the corally hauler bag....
HEWITT is offline
Old 05-25-2005, 06:15 PM
  #2211
danjoy25's Avatar
Trader Rating: 38 (100%+)
-Korey
Yep, I do have the same ones which I think came from the assasin days. No biggie.
danjoy25 is offline
Old 05-25-2005, 06:27 PM
  #2212
rcgen's Avatar
Default C hubs
What can be gained or lost by changing from 2 degree C-Hubs to 4 degree?
rcgen is offline
Old 05-25-2005, 06:47 PM
  #2213
danjoy25's Avatar
pretty sure its more steering as the front cambers alot more when turning.
danjoy25 is offline
Old 05-25-2005, 07:27 PM
  #2214
rcgen,
As danjoy, said, this will give increased camber-gain in the corner. But mainly, it will make initial turn-in less aggressive, and the car will have more corner-exit steering.
Old 05-25-2005, 10:06 PM
  #2215
Turbonium's Avatar
Trader Rating: 27 (100%+)
it holds 3 boxes, which measure..:
9 3/4 wide, 5 1/4 tall, and 19 long each, outside dimensions. very nice black boxes, with a red Corally label on each. the bag itself is...
16 1/2 tall, 10 1/4 wide, and 19 1/2 long. nice heavy duty zipper, and a pocket on the side.
the boxes will fit a electric touring car with the body on easily, in case anyone was wondering...
Turbonium is offline
Old 05-26-2005, 12:29 AM
  #2216
Cookie's Avatar
I just got the motor/battery case and it's very trick, well worth while!
It holds 6 batteries, 4 motors and two armatures, plus it has a small plastic container built in for brushes/springs/washers etc
Awesome!
Cookie is offline
Old 05-26-2005, 02:25 AM
  #2217
danjoy25's Avatar
Cookie,
Do you have any pics of that or a link where I can check it out.
danjoy25 is offline
Old 05-26-2005, 06:06 AM
  #2218
lazyboy's Avatar
Wink
is there a price for these bags... or do you have to be speical in order to be told the price
lazyboy is offline
Old 05-26-2005, 06:07 AM
  #2219
Turbonium's Avatar
they do have pics on corallyusa.com, i think. i got the case for just the batts, holds 12 (!) 6-cell packs. very nice!!!!!
Old 05-26-2005, 06:13 AM
  #2220
Turbonium's Avatar
well, im not sure exactly the street price, but from what i was told, i think the full retail on the hauler bag should be around 50-ish.... you might pm either jeff brown or "corally usa", or call 'em up to be sure...
