Team Corally RDX Touring Car
#1711
I noticed on the website that most of the setup are for carpet...Outdoor season start
I ran this weekend an asphalt setup that was dialed. with Spool
attached is setup notes..
I ran this in Mod and use the same setup for stock.. worked very well.
Car was smooth as glass.!!
#1712
Badboy- Do you have a blank copy of a set-up sheet that I can type directly onto? If so, please email it to me at [email protected]
#1713
White Pulleys
Machined delrin pulleys are in stock and ready for shipment. They are $18 a piece for them.
#1714
Re: White Pulleys
#1715
Asphalt Starting Setup
Ran this the last couple weeks....... I have tried other stuff but here is a starting point. Let me know if I left anything out.
Jeff
BODY: Mazda 6
FRONT:
60wt, 1.3mm piston, -1 camber, 2 deg caster, ultra low blocks, 19lb spring, 3rd hole out on arm, 3rd hole in on tower, 2nd hole top row camber link, 5mm ride height, Spool, 2mm uptravel
REAR:
40wt, 1.3mm pistons, -1 camber, standard roll blocks, 17lb springs, shock extentions on arm, 1st hole on tower, 2nd hole bottom row camber link, 2 deg toe in, middle hole on upright, 5mm ride height, 1mm uptravel
Jeff
BODY: Mazda 6
FRONT:
REAR:
#1716
Jeff- Are you guys still running on tracks using VHT with that set-up?
#1719
Brandon...... that is with a grape soda base. For VHT i would just stiffen up the springs one step and go to 4 deg blocks to start.
Sushi...... standard tower. We pretty much only use the lowered tower for carpet.
Jeff
Jeff
#1721
Corally WINS 12th Scale Euros!!
Congratulations to Sakke and Simo Ahoniemi for winning the European Championships this past weekend! Simo TQed and was defending champion. Sakke finally took home the European Title this year with Simo 2nd. Back to Back WINS for the brothers!
More info on http://www.corally.com/ under Racing News.
#1722
Re: Re: White Pulleys
Originally posted by sweet wasabi
How do I apply to be one of your team drivers?
Always help with questions people have at the track and setup information. Get local dealers to carry the product lines.
#1724
Jeff
Jeff
If anyone wants a set-up for "non" treated asphalt surfaces, send me a PM with your email. We do not race on soda or VHT and my car is working really good.
