how do you mount a painted body?
typically ill cut my body post holes and wheel areas out prior to having it painted. or at least ill trace the lines/holes with a perm marker on the outside wrap so i know where to cut.
i just bought a new body and it arrived today and i have to figure out how to cut the post holes.
the wheels i can figure out. how do you guys do it?
Put some black grease over the body posts, then lower the body over the posts keeping it aligned with the wheels. Black grease will mark the spots where body holes should be...
someone just gave me an advice with the exactly same question .
he suggested me with this https://www.ssl-stormerhobbies.com/c...&pn=IMXRCO9485
There are little metal cones you available you put on your post and when you center your body press down to make the impression.
