Which diff grease is the best?
Which diff grease is the best for ceramic ball?
thx~
thx~
I use a molytec silicon lube here in australia... Its rated to 200 degrees c and you can run the diff that free and it doesnt slip. Let me know if you cant get it and I will send some your way.
I dont have to replace balls and diff plates ever and it last about 10 to 15 races and then I rebuild. it takes 5 minutes to rebuild a diff and it costs me nothing but the lube.
It all depends on who's diff it is and what motor is driving it...
some greases work better then others depending on the conditions...
Associated diff grease in the plactic squeeze tube (with black writing, not the red write) is very good for mild Mod's and stocks. Schumacher diff grease for all mod's... imo
Schumacher
Schumacher
What is the difference between the red and black tube from associated?
I used to use the Hudy diff grease but recently tried some niftech. I really like the niftech stuff as the diff can be "tight" as in it wont slip, however when you rotate the tires its very free.
gear diff lol
seriously:
Schuie or Assoc black label
seriously:
