Tamiya Mini Cooper - Differential Grease???
I HAVE A TAMIYA M-03L MINI COOPER THAT I JUST PULLED APART TO ADD BEARINGS, CLEAN AND REGREASE. MY QUESTION IS HOW MUCH AND HOW HEAVY OF GREASE SHOULD I ADD TO THE MESS/BEVEL GEARS INSIDE THE DIFFERENTIAL SPUR GEAR? THANKS, DON
I had one and I packed it with black grease... PACKED
If you're packing the diff, make sure it's a heavy grease, not a diff oil.
The diff isn't sealed, so the diff oil will run out of the edges and become useless after a few runs.
HEAVY BLACK GREASE
I PACKED THE DIFF WITH HEAVY BLACK GREASE (monoject 412). IT SEEMS TO BE PUTTING A LOAD ON THE MOTOR, I RAN IT ABOUT 30 SEC. AND THE MOTOR WAS WARM AND THAN I RAN IT FOR 1 MINUTE AND THE MOTOR GOT HOT. THE GREASE THAT CAME WITH THE KIT THINNED OUT AFTER A FEW RUNS AND THE MINI COOPER STARTED TO MAKE THAT NOISE THEY MAKE (LIKE A COFFEE GRINDER). WILL THE BLACK GREASE THIN DOWN WITH A LITTLE USE? AND HOW HOT IS TOO HOT FOR AN ELECTRIC MOTOR? THANKS, DON
maybe you installed the motor onto the wrong pinion holes??
btw did you pack your keyboard's caps lock with thick grease too?
I USE A 17 TOOTH PINION IN THE 16 HOLE, AS DO A FEW OTHER MINI COOPERS. AND I GREASED THE SHAFT WELLS IN THE CHASSIS, ETC. I'M TRYING TO STOP THAT COFFEE GRINDER NOISE THE MINI COOPERS MAKE. AFTER I PUT IT TOGETHER THE FIRST TIME I TOOK IT APART AND REGREASED IT WITH THE GREASE THAT CAME WITH THE KIT AND THIS STOPPED THE NOISE FOR A FEW RUNS. NOT SURE WHAT TO DO WITH IT NOW, MAYBE I SHOULD INVEST IN EAR-PLUGS. THANKS, DON
Ron-
DO NOT put any grease on the gears themselves or inside of the gearcase, as this will reduce your speed and put a strain on the motor. You can put heavy grease inside of the actual differential case (that's the small round cylinder with the metal bevel gears inside and gear teeth around the outside) if you want to, but frankly that's never really increased performance for me like a ball diff does. I run my teeth dry. Yes, there's some gear noise, but there's really nothing you can do about it- although using a 17 tooth pinion in the #16 holes may make your car noisier.
Doc
Doc
"LARRY - OH WISE ONE"
I ALSO GOT SOME GOOD ADVICE FROM BRAD S. "THE BLACK GREASE IS THE WAY TO GO AND IT WILL THIN DOWN FROM USE." THANKS, DON
Doc try the Tamiya AW grease in a gear diff it gives good bite off the turn in the early 2-3 min of the race. After that you will feel the diff starting loosen up as the grease thins. It does thicken after the run though. You can also use it in your ball diffs to tighten them up.
Re: "LARRY - OH WISE ONE"
LARRY, "THE MINI COOPER MASTER" SET ME STRAIGHT! THE COFFEE GRINDER NOISE, AND ACCESSIVE HEAT WAS PRODUCED BY ME HAVING A NON TAMIYA PINION GEAR. I DID WHAT HE TOLD ME TO DO AND PUT THE STOCK 20 TOOTH TAMIYA PINION IN THE CAR. NO "COFFEE GRINDER" NOISE! AND A COOL RUNNING MOTOR.
HEY THAT'S GREAT! NOW CAN YOU PLEASE GET A NEW KEYBOARD THAT HAS A WORKING CAPS LOCK KEY. THANKS!
if you get a ball diff try and get the ta03 one not the mantaray one.the cast alloy side plates on my mantaray diff seem to be uneven makeing it very inconsistent.other guys i race with have ta03 diff and have no problems
GRINDING
I have the rover mini cooper mo3. When I turn the wheel all the way and run the throttle at a certain speed, the driveline produces this gnarly CGKGKCKGKCKGKKKCKKG sound and the car violently, like reaaaaly violently vibrates. Ive tried many different o-ring spacer setups in the cup, single oring inboard cup, two orings on inboard cup, single oring in outer cup, two orings in outer cup, and and oring in both outer and inner cups. None of these are working at all. It sounds like someone has dumped some rocks inside of a blender. Anyone know what I should try?
Caps Lock
[QUOTE=bst;760797]I HAVE A TAMIYA M-03L MINI COOPER THAT I JUST PULLED APART TO ADD BEARINGS, CLEAN AND REGREASE. MY QUESTION IS HOW MUCH AND HOW HEAVY OF GREASE SHOULD I ADD TO THE MESS/BEVEL GEARS INSIDE THE DIFFERENTIAL SPUR GEAR? THANKS, DON[/QUOTEhttp://www.rctech.net/forum/attachment.php?attachmentid=679417&stc=1&d=1292202 770
