Soldering gun or iron
Registered User
I have a craftsman soldering gun (230/150 watt heavy duty), and wdon't know if I should take it back and get an iron. Is the iron better?
Thanks.
Thanks.
Haven't used a Goot or an Unger, but I have used a Weller soldering station and I own a Hakko 936 soldering station. I really like the Hakko and Weller stations.
Registered User
They made a typo. 300w. lol
Anyways, that 30w iron isn't really enough for RC applications. You want an iron that will go up to 60w.
If you got around 75-85 bucks, get the Hakko 936 Soldering Station.
Edit: I currently have a Hakko Red 503 60w Iron that I got from Fry's for 11.00, and a stand from RadioShack for 8.00. Works great. Downside is that it comes with a fatter tip. If you want variable temperatures, get a station. If you want a cheaper alternative, get a good iron and a stand.
Just an FYI, Ungar was bought by Weller. So, Ungar no longer exist.
Registered User
I don't want to spend alot, since I don't do much soldering.
Would this work?
http://www.lowes.com/lkn?action=prod...123280-273-P2C
Would this work?
I used to used the big soldering stations. After burning a few up I got a cheap Weller 40 Watt iron from Sears, Lowe's or Home Depot. It has an orange handle and well for ~$15.
It is the best thing I have ever used. It is stupid hot. Building batteries is a breeze and soldering on motor wire or brushes is instant.
40W is the key. Lower (25W-35W) is too cool higher (80W+) is way too hot.
I've been using the same type 40 watt Weller for around 15 years, I've only had to buy 2 of them in that time but also had to replace the tip about 1-2 times a season. They are fantastic!!
Definitly go for a soldering iron. I agree that Weller is the way to go.
Depends.....
I've only got a 30 watt for battery connections (at the plug and on the motor) and that does fine but would need at least twice that for actual soldering of cells.
Registered User
Thanks alot guys. I'll try to get the weller
whooaaa!!. that's what we can consider an antique tool for 30yrs and still working?!!.. it really serve its lifetime warranty.
