Which diff grease is the best? >
Old 12-14-2010, 08:23 PM
Default Which diff grease is the best?
Which diff grease is the best for ceramic ball?
thx~
teamsanwa is offline
Old 12-14-2010, 09:06 PM
http://www.amainhobbies.com/product_...ferential-Lube
Kody is offline
Old 12-14-2010, 09:11 PM
jjfo80's Avatar
I use a molytec silicon lube here in australia... Its rated to 200 degrees c and you can run the diff that free and it doesnt slip. Let me know if you cant get it and I will send some your way.
I dont have to replace balls and diff plates ever and it last about 10 to 15 races and then I rebuild. it takes 5 minutes to rebuild a diff and it costs me nothing but the lube.
jjfo80 is offline
Old 12-14-2010, 11:02 PM
jonest's Avatar
I've tested several brands like associated, Schumacher, Hudy and found the new tamiya is slightly better.
The molytec sounds good but where to get it?
Thanks.
jonest is offline
Old 12-15-2010, 12:56 AM
2-Bad's Avatar
Trader Rating: 24 (100%+)
It all depends on who's diff it is and what motor is driving it...
some greases work better then others depending on the conditions...
Associated diff grease in the plactic squeeze tube (with black writing, not the red write) is very good for mild Mod's and stocks. Schumacher diff grease for all mod's... imo
2-Bad is offline
Old 12-15-2010, 01:40 AM
JayBee's Avatar
Trader Rating: 31 (100%+)
DITTO!!! Hands down
JayBee is offline
Old 12-15-2010, 02:39 AM
jake95's Avatar
Trader Rating: 27 (100%+)
Schumacher
jake95 is offline
Old 12-15-2010, 02:40 AM
jake95's Avatar
how much is it and where do you get it from thanks
jake95 is offline
Old 12-15-2010, 02:42 AM
Schumacher
Fastfreddy74 is offline
Old 12-15-2010, 03:40 AM
Regional Moderator
CarbonJoe's Avatar
Fister!
http://www.fister-rc.com/proguctions.html
CarbonJoe is offline
Old 12-15-2010, 05:45 AM
AGNO's Avatar
Shumacher and HPI (more fluid) http://www.amainhobbies.com/product_...ferential-Lube
AGNO is offline
Old 12-15-2010, 06:10 AM
Trader Rating: 20 (100%+)
What is the difference between the red and black tube from associated?
csabo is offline
Old 12-15-2010, 06:57 AM
jjfo80's Avatar
pm's sent
jjfo80 is offline
Old 12-15-2010, 07:11 AM
I used to use the Hudy diff grease but recently tried some niftech. I really like the niftech stuff as the diff can be "tight" as in it wont slip, however when you rotate the tires its very free.
Andy Z is offline
Old 12-15-2010, 09:38 AM
R/C Tech Elite Member
JayL's Avatar
gear diff lol
seriously:
Schuie or Assoc black label
JayL is offline
