e-revo 1/16 having braking problems please help!
hey guys i just picked up my merv today from rc pitstop and i have a question i have the esc in sport mode which is the default mode 100%forward 100% brakes 100% reverse and it says you pull the throtle trigger back to go forward and then push the trigger forward all the way for brakes then return the trigger to neutral position then push it forward again for reverse my question is when i push it forward for brakes it just goes directly into reverse it stops but its only stoping because its engaging in reverse im guessing this isent normal plus cant this be damaging to the tranny going directly into reverse from drive at high speeds plus its hard to control any ideahs why this could be happening and or solutions? is it safe for it to go directly into reverse? it cant be normal cuz its hard to control. thanks in advance for your time
