Old 07-24-2004, 06:27 PM   #1
Turbo9000's Avatar
zero delta V peak detection method
I am interested in purchasing a new charger HERE and i noticed it is able to charge NiMH batteries at a higher ampre rate than others due to Zero delta V peak detection. I currently run matched GP 3300's and they can get pretty toasty at 3 amps. For those of you familiar with this peak detection method please share your experiences.
Thanks in adv.
Turbo9000 is offline   Reply With Quote
Old 07-25-2004, 02:40 AM   #2
Cole Trickle's Avatar
I wouldnt go for this... it's a pulse charger and trickle charge cant be disabled...
For getting the optimal out of GP3300, you need adjustable delta peak cut off, linear charge, at least 6 amps charge rate and no trickle charge. As far as I know, the cheapest way to get this, is with the LRP Pulsar Sport, which can be found for 100$ (excluding a power supply).
If you are on a budget, well, it's hard choises. The Duratrax thing might be better than what you godt today, but look at it this way: 4 packs of matched batteries, can easily cost 160$. If your charger ruin these fast, you'll be better off buying a good charger now....
For a power supply, it might be an option to use a modified computer power supply, to keep costs down.
It's a good idea to save up a bit longer and get a good charger
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 07-25-2004, 03:04 AM   #3
I agree with Cole.......If you want to stay around the same cost.....you'd be better off getting yourself a "used" quasar pro or something along those lines....you cant go wrong spending money on a good charger
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 07-25-2004, 02:58 PM   #4
Turbo9000's Avatar
ok cool. Thanks for the input
F/T Dynamite Vision Peak 2 AC/DC Auto Peak Detection Charger InsaneRC R/C Items: For Sale/Trade 1 06-10-2008 04:04 PM
Dynamite Vision Peak battery charger peak detection speedemall R/C Items: For Sale/Trade 0 07-01-2006 11:49 AM
Peak Detection mV AZNracerx1989 Rookie Zone 8 07-27-2005 07:25 AM
Peak Detection AZNracerx1989 Electric On-Road 12 07-27-2005 03:48 AM
SEO by vBSEO 3.5.0
