Old 07-20-2004, 11:42 PM   #1
onnetz's Avatar
Default ? about using a lathe
I got a good deal on a used cobra 2000 lathe and it is my first lathe..
I have an old trinity 12x2 diamond motor from about 7 yrs ago and figured I would practice on it...
my question is, how do you keep the armature from moving back and forth?
I noticed in the pics that the armature they use fits perfectly between the two blocks....
the one I'm trying to cut has at least 1/2" of play between them.
thanks for any info..
onnetz is offline   Reply With Quote
Old 07-21-2004, 01:41 AM   #2
sosidge's Avatar
Depending on the lathe's design, you can either add some shims to the armature to space it out, or adjust the blocks that the armature sits on.
Old 07-21-2004, 02:01 AM   #3
Bugle's Avatar
I put one shim on the pinion end of the armature to stop the plastic rubbing on the block, then put a pinion on and position it so there is no noticable endplay and still spins freely.
Bugle is offline   Reply With Quote
Old 07-21-2004, 02:09 AM   #4
Super Moderator
Grizzbob's Avatar
Yes, I do something like that too. I just position the arm in the blocks & then put a teflon shim on the arm's output shaft, & then put a small pinion on top of that(& just LIGHTLY tighten the pinion down, don't push in on it when you tighten down the set screw, so it'll still spin smoothly), that does a good job of preventing the arm from scooting around when I'm cutting....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 07-21-2004, 02:14 AM   #5
onnetz's Avatar
so simple, yet effective...
Old 07-21-2004, 02:26 AM   #6
Also remember that on the cobra lathe, the slave motor must recieve "reversed voltage" to spin the arm being cut in the correct direction...........
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 07-21-2004, 10:24 AM   #7
Send a message via AIM to RcRacerX
You could also use a pen cap to pin the armature to one side or the other.
RcRacerX is offline   Reply With Quote
XXIP Comm Lathe and Orion Quick set lathe vino1 R/C Items: For Sale/Trade 2 01-25-2008 03:35 AM
Trinity Tru Lathe Motor Comm Cutter Lathe maximum R/C Items: For Sale/Trade 4 05-14-2007 03:56 PM
XIPP Super Lathe 3 / (pics) comm lathe diamond bit evostyle R/C Items: For Sale/Trade 8 12-01-2006 11:53 AM
Motor Lathe (Integy Xipp X-Mod Super Lathe) Geppetto R/C Items: For Sale/Trade 15 01-27-2006 04:10 PM
Tire Lathe, Motor Dyno, Comm Lathe For Sale 17Mark71 R/C Items: For Sale/Trade 8 06-05-2005 12:07 PM
SEO by vBSEO 3.5.0
