Old 11-26-2010, 03:43 PM   #1
sprintcarracer's Avatar
Trader Rating: 23 (100%+)
Default rubber tires for low grip carpet
I'm looking for rubber tires that are going to work good on low grip carpet. Need suggestions.
sprintcarracer is offline   Reply With Quote
Old 11-26-2010, 04:24 PM   #2
wtcc's Avatar
How about Sorex 24R or similar soft compounds?!
wtcc is offline   Reply With Quote
Old 11-26-2010, 05:48 PM   #3
Pro10noob's Avatar
Try the LRP CPX tires.
Just sand the molding line of the tire,clean it with brake cleaner and put some tire additive on it.
Wrap them in transparent foil and keep them that way for a day or 3,then clean them again with brake cleaner and put back on tire additive and warm them up with tire warmers.
That should work like a charm.
When putting on the tire additive for the second time on,do it on the whole rear tire and for starters just the outside half of the front.
Check if you have enough grip at the front.
If not do the whole tire,if to much don't sauce the front tires at all.
Just warm them up.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-26-2010, 06:39 PM   #4
Buckaroo's Avatar
Click here and read this. A little dated, but still 100% valid
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-27-2010, 12:13 PM   #5
RC MARKET's Avatar
Sorex 28R tire
Orion JB Foam Insert ( blue yellow blue )
Paragon Ground Effect
RC MARKET is offline   Reply With Quote
Rubber tires for dummies rayhuang Electric On-Road 391 06-02-2012 08:37 AM
How to cool down electric touring car rubber tires on carpet? maxg123456 Electric On-Road 34 08-16-2010 04:08 AM
New Jaco Rubber Tires yyhayyim Electric On-Road 601 07-07-2009 05:13 PM
Team MuchMore Absolute and Sweep Rubber Tires s13evo Electric On-Road 12 11-20-2008 02:30 AM
SEO by vBSEO 3.5.0
