LRP SXX TC V2 Problem!!
Hi! I'm from Spain and I bought this speedo recently in mushroom.
The first li-po pack finished with 50ºC speedo and 67ºC motor (LRP X12 4.5t octa wind). I plugged new li-po, turn on, run surrounding me to test some changes (xray t3) and suddently car stops without responding tx. I saw speedo with blue light off and interruptor turned on. off, on, off, on, another batt, nothing respond.
After 2 li-po, suddently turns off itself and never can be turned on. Setup 3-6-4-2, ratio 8.4, timing oooo, batt SMC 2s 6000mAh 60C, no inverted polarity, everything new.
I open a thread in LRP forums international section called "SXX TC V2 defective"
Anyone?? I'm really disgusted
Thanks guys!
Thanks guys!
there is troubleshooting guide by the user manual. just see what is the LED status to see what's the problem.
I've had the same with my SSX LRP Stock Spec. If it is no longer possible to turn on the speedo and no LED are lit. You will have to return it to LRP. He is dead. I had bought mine from the U.S.. and the warranty had expired. Got it sent from belgium to lrp usa and received a new one for free
I tested everything, but any light when conected. Trouble shooting guide say any light (with batt) -> send to shop Very simple.
LRP say that I may send it to shop, not directly. So speedo may fly Spain - Hong Kong - Germany - Hong Kong - Spain Mr LRP says that they can't receive directly de item, distributor decides what make.
email mushroom and ask him what to do. or where to send him to for repair
mushroom say that send it to their office for repair/change.
So I know the way for warranty covering.
Thank guys! I opened this thread to see if this problem was massive.
