Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-19-2004, 10:12 AM   #1
imjonah's Avatar
Default Pulse Chargers vs linear chargers
I ocassionaly see the advice make sure it is a linear charger
not a pulse charger. I also saw a note in once in charger's spec sheet that said it used linear charging up to 5 amps and pulse charging from 5 to 10 amps.
How do you tell weather a charger is linear or pulse?
I rarely see pulse or linear mentioned in the spec sheets.
Is it mostley cheap chargers which are pulse? or is it mostly smaller chargers.
If it is not to complex what exactly is a pulse charger and why is it a negative?
[I am guessing it has something to do with getting a higher amp charging rate out of smaller power supply]
I assume by 'pulse' they do not mean the brief polarity reversal circuit that some chargers had that supposedly helped when used ocasionally with nicad packs.
imjonah is offline   Reply With Quote
Old 07-19-2004, 10:21 AM   #2
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Hi,
I run the Pro Trak (I also am the Pro Trak contact in the US) which offers many varieties of charge type, linear or various types of pulse. I have found that when racing I use Linear as it gives better punch. When I'm just cycling my cells I use Soft Pulse, as I recall this uses a rest period of 1/4 of a second every second, this is supposed to help with the internal structure and stress in the cell but it takes 25% longer to charge, when I'm cycling this is not an issue.
There are a few types of pulse charge, one of the pulse profiles will give a discharge pulse instead of a rest period, the will obviously take even longer to charge.
crimson eagle is offline   Reply With Quote
Old 07-19-2004, 01:14 PM   #3
SalvadoriRacing's Avatar
Send a message via ICQ to SalvadoriRacing Send a message via AIM to SalvadoriRacing Send a message via MSN to SalvadoriRacing
you can charge your nimh pack with a pulse charger.....
simply check if the charger make a BZZZZ noise.....
if your charger DOES it, it'll hurt nimh cell because this noise means that the pulse current is too high.....
Salvadori Racing
www.salvadoriracing.com.br
NOVAROSSI - LRP - MATRIX TIRES - CORALLY
SalvadoriRacing is offline   Reply With Quote
Forum Jump
FS or Trade 2 - Duratrax Intellipeak Pulse Chargers Hawktoy85 R/C Items: For Sale/Trade 0 01-26-2007 11:00 PM
T4, Chargers, Dyna pulse, 0-30, V2-motors dodgeguy R/C Items: For Sale/Trade 25 09-29-2006 12:01 PM
trades-chargers for power supply and lrps chargers rcnutmich R/C Items: For Sale/Trade 2 03-27-2005 08:38 PM
Linear/ Pulse charging Crashmaster Electric On-Road 10 05-04-2004 02:09 AM
pulse chargers & nimh cells SalvadoriRacing Electric On-Road 20 01-08-2004 05:40 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
