What kind of fiber glass board for our rc chassis
Where can I buy it? I want to cut it myself.
It's called G10 if you want fiberglass parts. Most of our parts are made from carbon fiber.
Before carbon fiber became the standard for chassis', G10 was used and is still used on some parts like T-bars. G10 is also known as circuit board material. It's available from most plastic supply warehouses and online. Cutting it can be difficult as it is very abrasive and will dull high speed cutting tools quickly. You will need carbide to cut it efficiently.
3racing sells woven graphite plates for cutting your own chassis.
They are all back ordered though.
http://os.3racing.hk/products.php?products_key=457
McMaster-Carr
http://www.mcmaster.com/#grade-g-10/...rolite/=9sg9v3
You want the G10/FR4 garolite.
Word of caution, wear a mask when you cut it. Breathing that stuff is NOT GOOD for your lungs and sinuses.
I've made a number of chassis out of Team Cobra G-10. Much easier to work with than carbon. There is also some companies on line selling it as rocket fin material. Don
If you are going at this with a hand tools, good luck and make sure you have plenty of spare cutting tool.
